Piotr Pe
Flight distance : 338428 ft
Poland
Fuxflight Posted at 3-20 23:17
The reason Remote ID is only activated with the plus batteries, is because Remote ID is not required per se if your drone is less than 250grams. With the plus batteries your Drone is more than 250g and needs to have Remote ID activated. That is probably the main reason.
The Mini 3 should be classified as a C0 drone with the normal intelligent batteries (drone weight about 249grams, less than 250grams). I am not sure why DJI gives C1 label to this drone.
In my opinion, it is stipulated in the EU that drones with MTOM > 250g are classified as C1. If the drone is class C1, it must send Remote ID.
MTOM is the maximum mass and is different from the take-off mass. The take-off weight cannot exceed the maximum weight
This means that all mini 3, 3pro and 4pro must have RID enabled, regardless of their the take-off mass . |
