Bashy
Flight distance : 2354357 ft
djiuser_702yrLiY0CXt Posted at 1-30 07:29
I don't see it as a foot shot, but I know the capabilities of these devices, correct the rainy season here, however the drone was never flown in the rain or anything similar.
I say this because I have friends who have used the mini 3 pro in waterfalls in rainforest and have not had any problems with the camera, if for a little humidity the camera is damaged, no landscape content creator would use a dji drone.
Youre still confusing the 2 issues, the 1st issue is the camera, this is a known issue and may take many uses before it shows or it could be on the 1st flight, the seal for the camera was pinched during manufacturing.
When you sent the drone in, if the issue was only the above, they would have replaced it or the drone, no questions asked. The problem youre facing now is down to issue number 2, somehow the drone has managed to get moisture inside, the litmus paper has turned red, you've already stated that the box was fine and sealed so you got a new drone, therefore, sometime during unboxing and being returned to DJI, it got moisture inside. This is the problem youre facing right now, forget the camera, thats secondary, the primary issue is the inside of the body.
Youre only hope now is that DJI will exchange it in good faith on the benefit of the doubt, but you will be very lucky if this happens. The litmus paper is their get out clause, despite how their drones have been flown, you are not supposed to fly in rain, snow, waterfalls, fog, mist and anything else thats wet. Im sorry but thats it, its in the manual pg 20
