FrancoCL
Chile
Hello,
I have a doubt about the mrk file, that it will be great if someone could clarify. In the user manual, in the section Image Log File, says that there are compensation values in north, east and elevation (columns 4, 5 and 6).
4. Compensation value in the north direction: unit is mm and the northern direction is represented by a positive value.
5. Compensation value in the east direction: unit is mm and the eastern direction is represented by a positive value
6. Compensation value in the elevation direction: unit is mm and the downward direction is represented by a positive value
After that, it says that the compensations already have been applied to the longitude and the latitude, but in the height it doesn't say if there are applied.
7. Longitude after compensation.8. Latitude after compensation.
9. Ellipsoid height
Can somenone clarify if these compensations in height have also been applied to the ellipsoid height ?
Thank you !
