Frunobulax
Flight distance : 12936 ft
Manitobahunter Posted at 2-5 19:20
Been going on since the December update. I'm happy more people are starting to report it, as DJI needs to get this fixed!
It involves the homepoint, although it seems the firmware still knows where the homepoint is, and will auto return, after more than a month with no firmware fix, its undermined my confidence in the whole setup. Basically its taken a lot of the fun out of flying the Mini 4, which is crappy because when it was working properly prior to the December update, the Mini 4 Pro and RC2 combo was a technical marvel, and with the ocusync 4, utterly amazing to fly!
https://forum.dji.com/forum.php? ... D924%26typeid%3D924
I agree with you 110% on everything you have said. also like i stated the map view seemed to have the home point. just kind of clunky to have to switch to that to get home or keep switching back and forth lol.
also like I mentioned about the error message on the display, sd card too slow, was not slow till after this last update, then after the update says sd card slow. I assume it means the card in the RC2? both the drone and the RC2 have the same card. |
