LV_Forestry
Flight distance : 4726654 ft
Latvia
DroneNewbie88 Posted at 2-7 00:29
Thanks for the info.
However, how do I determine what is considered significant to change the Target Surface to Takeoff Point?
In principle, the altitude is determined last, based on the GSD. The starting altitude is always zero. Only if you use an ASL flight plan does this data come.
If the GSD is fixed, when you will offset 5m, the flight altitude will also take +5m.
For the same GSD!
