sultangris01
This, saved video file playback chop or live feed chop? live feed chop is possible due to a variety of reasons and not likely due to these pins. usually live feed chop is from the display device becoming hot and throttling down its cpu to reduce heat output. if this is your problem you can lower the live feed transmission bitrate, stand in the shade, or if its an apple theres some issue with recording to the device while flying that if you shut off will reduce the problem. there a couple more possibilities as well, depending on what hardware, app and firmware versions youre using. |
