Quantum41
Tried in vain for over a month or so to take images off my bird (drone: DJI Mini 4 Pro) and directly onto my iPhone 13 (iOS 17.3.1). The bird DOES NOT HAVE an SD card - just native onboard storage that is installed by DJI at the factory. No process I've tried will work - no wireless, no cables, etc. I'm at wit's end on this.
I'll relate everything I've done, or know so far.
1) Bird and DJI Fly mobile app on my Iphone: Firmware Up to date on bird, latest version of DJI FLY with QT (Quick Transfer refinements) so - up to date on both.
2) My bird package came with the RC 2 controller. Bird and RC 2 are paired, work fine together. I fly with no problem. I just can't get the images off. It used to be easy with the RC-N2 controller, but not now.
Continuing with data on my problem:
When asking for help INSIDE DJI fly, in the QT section, entitled: The "Device not found?" link here's what it says:
Help:
Check availability: QT is available on DJI Mini Pro 4 (and a bunch of others), so I'm good here.
App Permissions: Required permissions allowed. Restart aircraft if search continues to fail (It does - I have). Make sue aircraft is within 1 meter radius of mobile device (it is) and search again (I have).
continuing...
Using QT on the following aircraft models:
DJI Mini 2: press and hold aircraft status indicator on the rear of the aircraft to enable QT mode
DJI Mini 3: press power button 3 times to enable QT
<NO DJI Mini 4 specific directives....>
Trying to connect them (DJI FLY and the bird)
1) DJI fly on my Iphone knows my home network, finds it, and then asks me for the spinning bird to join.
2) I say yes - the bird image spins and spins and they don't connect.
3) I get a results screen that says: connection fails, try again. Not much help to diagnose what's going on but....
3) I look at my iPhone and the password for my iPhone to talk with my home network is changed!! Therefore my iphone flips itself back to cellular, and I have to forget my house network, and re-add my iPhone back to it. In all honesty - NOTHING (no app) should change my iPhone network password for my own network!!
Maybe I can get a list of help steps from someone knowledgeable about this. Some thoughts about what I need to check on, but can't seem to find:
1) Where do I give the bird and or the RC 2 controller access to my home network, if they need that? Where is that stored and how can I change or edit it?
2) Is the bird and DJI FLY trying to establish their own connection somehow?
I've watched tons of videos on people doing this with cables (tried that) and read on some success with SC DATA cards, but I'm not using one. I'm using onboard native storage, and that works great.
I just can't get the images off at all.
Thanks in advance,
Q41
