Follow Me Problem
1455 11 2015-9-10
jb
Flight distance : 270728 ft
I am using a P3P, using Samsung Note 4 for my mobile device.  I am flying above 10 meters but the Follow Me feature feels very irratic.  Sometimes it follows a bit and but usually it just hovers.  I am in a park and walking.  I am wondering what your experience is with Follow Me?
2015-9-10
Willie Wonka
Follow me is just a proof of concept, i think it will be perfected with a better algorithm later on, its a fun thing to play with but not a thing to rely on in my humble opinion.
2015-9-10
aburkefl
Flight distance : 78612 ft
The "follow me" modes I've seen from competitors have generally fixated on much more rapid motion - dirt bikes, bicycle motocross, etc. That produces a lot of action, therefore lots of movement and the quad is generally much more significantly active.
Someone walking around just seems too slow.
Art Burke - N4PJ
Leesburg, FL
2015-9-10
Ulysse
Flight distance : 1389931 ft
Belgium
Maybe is this a problem with your tablet GPS not accurate enough.
2015-9-10
jb
When I contacted tech support the guy said, you either have GPS or not.   Someone mentioned re calibrating the IMUs.   I will do that and then go to another park to test again.
2015-9-10
Sling Shot
Willie Wonka Posted at 2015-9-10 12:29
Follow me is just a proof of concept, i think it will be perfected with a better algorithm later on, ...
I agree with you brother...they need to work the kinks out a little
2015-9-10
Sling Shot
aburkefl@gmail. Posted at 2015-9-10 13:49
The "follow me" modes I've seen from competitors have generally fixated on much more rapid motion -  ...
5 to 20 MPH...works best
2015-9-10
DJI-Tim
since your mobile device GPS refresh rate is not high, and probably signal is not very stable, so you're facing this problem. Our R&D are working on Follow me improvements.
2015-9-10
aburkefl
DJI-Tim Posted at 2015-9-11 03:03
since your mobile device GPS refresh rate is not high, and probably signal is not very stable, so yo ...
"Hey honey! Can I keep it? It followed me home!"
2015-9-11
TheDreamingWatc
Austria
jb@jamesstudio. Posted at 2015-9-11 02:03
When I contacted tech support the guy said, you either have GPS or not.   Someone mentioned re calib ...
IMHO, that's not true.
Some devices have GPS and Glonass (like the Phantom or the iPhone), some have only GPS.
GPS and Glonass is more precise than only GPS.
Some devices have a bad reception because of the casing, some have a better reception.
I’m sure there are several other factors to improve or reduce the accuracy.
2015-9-11
jb
DJI-Tim Posted at 2015-9-11 02:03
Are there mobile devices that are know to have high refresh rates?  Which devices work well with the Follow Me feature?  For example, do the Apple devices with cellular work well?
2015-9-26
ksunsingh
I have a P3P and samsung note 4 and mine did pretty well, i even ran.  Height was 10-12m.
I was able to trick it by suddenly changing velocity.  But thats cause of momentum and it would adjust to catch me again.
2015-9-26
