DJI GO App using Raspberry Pi 4
391 1 2-14 12:14
Pat21
Austria
Hey everyone,
I recently got myself a Raspberry Pi 4 with 8 GB and installed Lineage 20.0 (Android 13) to run the DJI GO App. Here's a brief overview of my setup:
  • Powering the Raspberry Pi using the USB-C connector with the Phantom 4 remote controller.
  • Data transfer via the USB-C connector (USB-OTG).
  • Added a touch screen to the Raspberry Pi powered by a powered USB Hub and a Power bank (because the remote control deliveries too less power).
However, I'm encountering an issue with the P4 remote controller connection. Sometimes, when I start the Raspberry Pi with the remote controller, it doesn't always recognize the connection with the DJI GO App. The USB debugging is normally turned on, but sometimes when the Raspberry Pi starts, it is not in debugging mode, although the debugging mode is on in the settings. To resolve this, I've found that toggling USB debugging off and on in the Raspberry Pi settings (Android 13, Lineage 20.0) usually helps establish the connection.
The challenge here is that after a few restarts and toggling USB debugging off and on, the Raspberry Pi might not consistently recognize the remote controller, making it less reliable. I experimented with other operating systems from different providers, but they either couldn't recognize the drone or didn't perform as well as Lineage.
Has anyone else faced a similar issue or found a more reliable solution? Your insights would be greatly appreciated!
Thanks!
2-14 12:14
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We totally understand your expertise regarding electronics. However, the DJI Go 4 app can only be downloaded and work with mobile devices which are listed on our website. You may click the link below to have the list. Please note that we haven't tested this setup therefore we cannot provide any guidance about this connection. Should you have other inquiries, feel free to contact us. We appreciate your understanding and support.
https://www.dji.com/global/downloads/djiapp/dji-go-4
2-14 22:15
