Hello.
I am using a Mini 4 Pro with RC2.
At initial screen I tap Album and get message that there are photos or video.
I have SD card selected as storage in the drone anf if I use USB connection to PC I can see them.
Is this normal?
Thank you.
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please provide us with a short video or screen recording showing the issue so we can check it further? Please make sure to connect the aircraft to the remote controller and go to "Album" then switch to the left album to check the photos/video in the aircraft. Please keep us posted.
Hello, Rogerio53. Thank you for reaching out. May I confirm that the photos and videos are not showing on the DJI RC2 under Album? Please confirm if the DJI RC2 is connected to the aircraft upon checking the Album. Also, please know that the aircraft will save the original files and the DJI RC saves the cache file which can be downloaded as well. Furthermore, both files from the aircraft and remote controller can be exported upon connecting to a computer. To learn more, please visit the links below. I hope this information helps.
DJI Paladin Posted at 2-15 22:18
DJI Gamora Posted at 2-15 22:31
Problem solved. The problem is that I renamed the files in the SD card.
Today I did another movie and kept the name. And it apperars in "Album".
Thank you.
DJI Paladin Posted at 2-17 02:58
Thank you for your response. We will coordinate this with our relevant team for further clarification. We will keep you posted.
Thank you.
rogerio53 Posted at 2-18 05:18
Thank you.
Perfect! We're glad that you have managed to isolate the issue that you experienced. We also appreciate you for sharing the fix that you performed. Should you have other inquiries, feel free to contact us. Have a good one!
