Noise levels
7850 16 2-19 01:16
trainee
Flight distance : 185686 ft
Thanks to some Mini 3 Pro noise testing by Youtuber Tech Drone Media I have adapted the chart below to conveniently illustrate where the M3P/M4P fit into the noise spectrum of familiar sounds. Does anyone have other/more scientific data?
Drone noise in context
2-19 01:16
trainee
2-19 01:20
The Ollie
Flight distance : 117694 ft
I compared the loudness of my Mavic Air and the M4P (2m distance):
Mavic Air
Mini 4 Pro
Propellers are running, drone on the ground
51 dB(A)
51 dB(A)
Drone hovers in 1,5 m heignt
76 db(A)
67 dB(A)
This means that the M4P is about half as loud as the Mavic Air
2-19 04:24
trainee
The Ollie Posted at 2-19 04:24
67 dB is quite a bit louder than the 61 dB measured in the (M3P) test above. Maybe wind noise or other ambient sounds made the difference?
2-19 04:35
harweyko
Flight distance : 873786 ft
official noise level of Mini 4 Pro as per DJI measurements for C1 classification is 81 dB (same as Air 3): https://support.dji.com/help/con ... Id=34&re=DK&lang=en
2-19 04:51
The Ollie
trainee Posted at 2-19 04:35
I measured it inside, because I didn't  want influences from outside sounds, but so I got reflections from the walls instead.
In summary:
Outside, I always knew where my Mavic Air was.
After a few meters you can hardly hear the M4P anymore.
2-19 04:52
The Ollie
harweyko Posted at 2-19 04:51
[view_image]
WOW. This is probably the maximum volume when you go full throttle in sport mode
2-19 04:58
trainee
[view_image]
That's good info but 81 dB is presumably the max noise level, ie in Sport mode at full throttle.
2-19 05:01
Jan Spacil
Flight distance : 115272 ft
Czechia
Maybe I don't understand this measurement quite right, but the difference between 67dB and 76dB means the Mavic would be eight times noisier, not twice ..
2-19 06:04
The Ollie
Jan Spacil Posted at 2-19 06:04
If you're referring to the power of a signal, you're right, that's 3dB twice as much, so 9dB is eight times.
Psycho acoustics probably behaves a little differently here, there 10bB feels like doubling.
According to my perception, it is actually twice as loud and not 8 times as you suggested.
This also corresponds to the following definition:
Definitions:
Sound level or noise level is a physical quantity measured with measuring instruments.
Loudness is a psycho-physical sensation perceived by the human auditory perception or the human ear/brain mechanism. That is not the same.
We are told by psycho-acousticians that a level 10 dB greater usually means "double the loudness" or "twice as loud".
A decibel is one-tenth of a bel, which is the logarithm of the ratio of any two energy-like quantities or two field-like quantities.
Ratio doubling means:
− a power level of +3 dB, or a sound intensity level of +3 dB
− an electric voltage level of +6 dB, or a sound pressure level of +6 dB
− a loudness level of about +10 dB
−10 dB more SPL means 10 times increase in amplifier (electric) power.
In the newsgroups these often misunderstood statements are explained rather less accurately. Decibels can also mean dBSPL or dBA, while a level change is always in dB. The perceived loudness of the sound depends on several factors: the amplitude, the sound pressure level, the frequency, and the time behaviour of the sound. A typical question on the internet: "Is 3 dB or 6 dB double the loudness?"
The answer is: "It is neither 3 dB, nor 6 dB − it is closer to 10 dB".
Source reference: Sound technology calculator
2-19 06:28
Jan Spacil
I had no idea, it's been many years since we discussed this in school, thanks for the clarification! :]
2-20 01:01
Montfrooij
Flight distance : 2770725 ft
In practice the Mini 3 Pro is usually audible for me.
Even at 120m.
Until it flies about 50m away, so I know I'm closing in when I start hearing it.
3-12 09:26
djiuser_uyHLlZuZInfK
The mini 4 pro sound can't be heard at 150 ft. But the avata that I measured at 111 dB at hover can be heard at 400 ft and up to a block away.
7-20 09:35
djiuser_yEvnMfzoKipF
Flight distance : 660282 ft
Poland
trainee Posted at 2-19 05:01
No, this is not the "max" noise. After class change from C0 to C1 DJI Mini 4 Pro is much louder then before change. This should be informed before change. There should be a way to change it back from C1 to C0, because this is misunderstanding.
8-18 11:22
BaynhamPhoto
Flight distance : 427969 ft
djiuser_yEvnMfzoKipF Posted at 8-18 11:22
Some qualification should be provided for this statement, on what basis is the mini 4 louder post C0 declassification?  It is possible use of a plus battery may enable higher prop rotational speed  impacting sound level but I have seen nothing to support this over marginal performance in resisting higher wind speed. Please elaborate.
8-18 13:22
trainee
My M4P is still C0 but I'm sure it seemed quieter after updating firmware this week.
8-19 01:59
BaynhamPhoto
trainee Posted at 8-19 01:59
Running master airscrew super stealth so mine usually sounds quiet anyway, not sure it is but definitely a better tone to it.
8-19 07:19
