GisGuy1
DJI Gamora Posted at 3-1 00:48
Hi, GisGuy1. Thank you for reaching out. YAW refers to the horizontal direction, which can be east, west, south, or north. "GimbalYawDegree" refers to the direction in which the camera is aimed. "FlightYawDegree" refers to the current orientation of the aircraft, where 0 degrees represents true north, 90 degrees is east, 180 or -180 degrees is south, and -90 or 270 degrees is west. Apart from the Mavic 2, Mavic Air 2, and DJI Air 2S, the direction of the camera is generally consistent with that of the aircraft. Hope this helps.
so if the Gimbal is perfectly in line with the aircraft, the value will be 90? If so, is 0 towards the counterclockwise or towards the clockwise? |
