DowntownRDB
QSmally Posted at 3-14 09:05
I see. I tried earlier today but higher in the air than the video I attached, it still 'stutters' while doing the movement test. It seems that it lags a bit when I hold the roll stick left or right in order to come to a stop, too. I cleaned the sensors and brake mode worked fine
Safe to say that I'll be using brake mode over bypass for now ._.
You might download the DJI assist 2 and refresh the firmware on your controller. You could also check the stick calibration. Other than that I'm not sure what else you could check. I do hope you get is solved soon. |
