ghoonk
Flight distance : 394626 ft
United Arab Emirates
I'm sorry - I didn't quite understand what you meant.
In Follow Me, the altitude is determined at the point of engaging Follow Me. I have checked my flight logs and the H value (height, I'd assume) is consistently the same, and this is not relative to the RC.
My flight ceiling is currently set to 500m, usually because the high dunes around here are that high.
So, I have no idea what you mean by "plan the altitude [I] will use the follow me all the way". Are you referring to Failsafe and RTH? If you are referring to Smart Go Home, then yes, mine was switched on when it was in Follow Me mode. Also, since the connection was not lost, why would it trigger an RTH? |
