Serg SSA
Flight distance : 6406329 ft
Russia
Once again, you don't understand how scanning works. The signal is emitted at one point, then the source is shifted by one pixel and the signal is emitted again. And so you need to scan 360 degrees and build a 3D map. Every second you need to create at least 10-20 3D cards. I have already told you that very large amounts of computing power are required. Well, and most importantly, how will you deflect the beam of an infrared source to each point on a 360-degree sphere? Lidar uses a mirror) |
