Stylus that works with the M3T Enterprise RC controller
1402 4 2024-4-4
Dogpilot
Flight distance : 2158192 ft
I am sure I am not the first to want to use something with a bit more precision than my fat fingers to select areas for survey. It became even more apparent when I wear gloves. It has been plenty cold this winter and I find I am wearing gloves about 90% of the time flying. Big problem is; the darn screen needs your bare freezing fingers to actuate many things. So I poked around and really didn't find anything discussing it, except old Phantom series threads. I took the leap. I found this Active Stylus works just fine. I got it when it had a 20% coupon so it was even cheaper. There are piles of them available that seem to be the same one or slightly different that will work as well. I just took the chance for $12. There are active and passive stylus' The passive ones are soft rubber or a mesh about 1 cm in width. Not so accurate or better than my finger. I tried my Apple Pencil, nope it does ot work. The active ones have a finer point and the mesh passive as well. They recharge, perhaps my big dissapointment, with USB micro, not C. It seems to get around 10 hours of use, charges faily quickly. It does work on my iPhone Max and my iPad as well.
One version that worked
2024-4-4
LV_Forestry
Flight distance : 4726654 ft
Latvia
Logitech MK235 Durable Wireless Keyboard and Mouse Combo
2024-4-4
Dogpilot
Oooh, that is clever.  Naturally I will need to poke about a bit to see where you pair the items. I see a bluetooth option, but never tired it except for phone pairing, which was hugely unsatisfying. I just found the stylus convenient for wearing gloves, since I can snatch it out of my jacket pocket quickly.
2024-4-4
LV_Forestry
Latvia
Dogpilot Posted at 4-4 10:34
You just need that with RC PRO :
Amazon.com: Anker USB C Adapter (2 Pack),High-Speed Data Transfer, USB-C to USB 3.0 Female Adapter for MacBook Pro 2020, iPad Pro 2020, Samsung Notebook 9, Dell XPS and More Type C Devices : Electronics
And it should work!
2024-4-4
Dogpilot
Actually have most of those elements in one form or another. Have to check it out later.
2024-4-4
