AIR 3 main camera optics not OK ?
12
4467 48 2024-4-10
TerryOregon
I will keep it.  Not everyone can live without an acceptable 1X camera.  I understand that, but I can.  If I go through the repair process again, the replacement drone will come from the same DJI Mississauga Canada warehouse.  What are the odds?
2024-11-23
TerryOregon
Couldn't delete duplicate post.
2024-11-23
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
A sad problem has been detected.
The main camera does not tolerate frost.
At temperatures below -10 degrees Celsius, lens distortion begins to occur. At -5 everything is fine.
In the cold, the lens cools down very quickly.
2024-12-16
Hallmark007
Flight distance : 12400594 ft
Drone.Hunter Posted at 12-16 02:16
Operating Temperature
-10° to 40° C (14° to 104° F
They are the specs for the air3 , temp in the air can be a lot lower than on the ground. How are you measuring the temperature at altitude.
2024-12-16
Drone.Hunter
Kazakhstan
Weather forecast and sensor in the car.
2024-12-16
Hallmark007
Drone.Hunter Posted at 12-16 11:03
Yes but thats temp at ground level, so if its say -10 then at 100m altitude it could be well over that , you can use apps like UAV that will give you approx temperatures at different altitudes.
2024-12-16
Eremita
Flight distance : 38945879 ft
Finland
Last winter I had the same problem when it was freezing cold outside. When spring came the problem went away. We'll see if the problem happens again this winter.
2024-12-17
djiuser_ItoPWuak03bw
Flight distance : 628980 ft
Czechia
I got the same problem with my Air 3 - the tele lens is so so...when I sharpen RAW (DNG) files taken with tele lens, Im relatively OK with the result. The wide lens is almost always unsharp (my DJI mini 1 was way sharper - I understand it was taking jpegs and DNG´s are designed to be adjusted. But even after sharpening them in Lightroom to max, they arent sharp at all (ISO 100, f/ 1.7 1/2500 s!).
Who should I contact in Czechia to solve this issue? Seller? (I bought it via Alza.cz)..
THX for advice.
1-12 15:10
Geo_Drone
Flight distance : 3001542 ft
Romania
djiuser_ItoPWuak03bw Posted at 1-12 15:10
Contact DJI using the warranty form, is faster...
Also make sure you send first some pics and video related to the issue....I have sent them a video with a large car park, all cars from right side in upper part were blurred a lot, showing the issue of the main lens.
Cheers.
1-12 22:52
12
