New DJI Goggles 3 Firmware Released (01/09/2025)
63103 511 2024-4-11
OldGuy2024
Flight distance : 632428 ft
When accessing the Menu>About>Battery we have battery cycle count data available for the Avata2 and Neo batteries.
YTube Neo video, the presenter's RC2 noted specific battery cell voltages on his Neo.
Assuming the Neo's intelligent battery system is similar to the Avata2.
Would a firmware upgrade allow for adding battery cell voltage to the Goggles3 OSD?
Right now I'm landing most flights with at least 30% battery capacity remaining. No idea of the cell voltages. Worry about dropping those voltages too low under load and damaging, reducing capacity, reducing life cycles.... Real old school hardware and LOS platforms have not flight battery telemetry.  Use a timer, check capacity, IR of cells and if needed adjust timer or retire tired batteries.  Newer hardware outside of DJI platforms have real time voltage cell OSD.  I understand the DJI "intelligent batteries" have some sort of algorithm that determines low battery RTH, critical low battery auto landing, power output limits in M mode once you reach a point of potential damaging voltage sag.  Maybe too old a person. Would like  to see real time cell voltage to determine time to back off on throttle input and maybe land.  Intelligent features are nice.  Bit like air bags in a vehicle.  Added safety vs. cell voltage OSD(the seatbelts).
2024-10-29
DJI Gamora
OldGuy2024 Posted at 10-29 07:22
Hi there,
We are truly sorry for the inconvenience you are experiencing.
Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
2024-11-5
Kyokushin
Flight distance : 296381 ft
Poland
Regarding: Goggles 3 Firmware: v01.00.0600
The question: for the Avata 2 the "Live view" cannot be adjusted, but its enabled or disabled by a default?
P.S.
For the neo its working poorly, consuming too much of FOV.
2024-11-7
DAFlys
What does "Added Landing Protection when used with DJI Avata 2." actually mean?
2024-11-7
Max Phlanx
Flight distance : 1223816 ft
DAFlys Posted at 11-7 00:46
I tried to find out yesterday after updating. As far as I can tell its a warning that pops up when you are about to land so you can confirm that is what you want to do. I could see no options anywhere to turn this on or off so it must be set on by default. That's my best guess until someone more knowledgeable chimes in.
2024-11-7
DAFlys
Max Phlanx Posted at 11-7 02:30
So you have to take your hands off the remote to press buttons on the goggles to confirm?
2024-11-7
Max Phlanx
DAFlys Posted at 11-7 03:32
Honestly I do not know. That was the best my late night internet search skills could find out. The same feature was pushed on to other dji drones and from what I could find out many people were not happy because it could not be turned off. Sorry I cannot be more helpful than that. I will find it tomorrow if the weather holds out and report back.
2024-11-7
DAFlys
Max Phlanx Posted at 11-7 06:49
I'll hold off upgrading for now then,  thanks.
2024-11-7
Max Phlanx
https://forum.dji.com/forum.php?mod=viewthread&tid=289608
Some more info until someone from DJI tell us exactly what it is?
2024-11-7
Kain_niaK
Philippines
Max Phlanx Posted at 11-7 06:52
https://www.youtube.com/watch?v=PMKZoRxI1xw
I am not going to upgrade, I am even still on the beta version that fixed the 03 problems. It works great the only bug is the sd card menu is chinese now.
Anyways, what I do know is with the avata 2 from the beginning if you are in sport or normal mode and you are are trying to go through a slot or something there is a risk that it will auto trottle. Why? Because it tries to always keep itself 30 cm of the ground. So when flying throught a small slot this can kick in, it will think it's closer then 30 cm to the ground and raise the trottle.
So I wonder how this behavior will chance with the new landing protection ...
2024-11-7
fichek
Flight distance : 1378789 ft
Croatia
Kain_niaK Posted at 11-7 08:32
No, it will behave the same as far as 30cm altitude limit is concerned.
And yes, you can turn landing protection off in the safety settings.
Also the Chinese menu option for SD card has been fixed (I think that may have actually been fixed in the public version of O3 fix firmware?).
2024-11-7
fichek
Croatia
DAFlys Posted at 11-7 06:51
You can turn the landing protection off (see screenshot in post above this) and there are some bug fixes, there's really no reason to hold off upgrading.
2024-11-7
t0dA
Portugal
Got my avata 2 one week ago and I'm loving it. Now, I saw that this last update brings the power loop function is making me excited, for a noob like me in fpv! thanks DJI
(first post btw)
2024-11-7
Kain_niaK
Japan
fichek Posted at 11-7 14:08
Thanks for the info! Can you explain what exactly is the behavior of landing protection?
2024-11-7
DAFlys
fichek Posted at 11-7 14:09
Great,     theres so little information about this it's hard to know what to do sometimes.
2024-11-8
Swedrone
Flight distance : 15419022 ft
Sweden
You can turn it off in the goggles setting now. But this also removes the 30 cm lowest height protection when flying close to the ground. "Added Landing Protection" in What's New
is kinda misleading.
2024-11-8
Swedrone
Sweden
Thank’s for the update DJI.
2024-11-8
Siwoo99
Flight distance : 1500965 ft
South Korea
When will Avatar 1 be supported?
2024-11-8
Max Phlanx
So weird because this option is not showing for me! I updated from goggles 3 fm v04 to 06. I will try updating again. Thanks for showing us what it should look like.
2024-11-8
Swedrone
Sweden
Thanks a mill for the Power Loop. Now add Split-S and Rubiks Cube please
2024-11-10
DJI Gamora
t0dA Posted at 11-7 14:46
(first post btw)
Hi t0dA, Thanks for sharing your feedback on our service. This will surely strengthen our customer relationship and foster advancement in customer service between our DJI customers. If you have any other questions, kindly let us know. Thank You!
2024-11-13
DJI Gamora
Swedrone Posted at 11-8 02:04
https://youtu.be/XWhsuKUE-bY
Hi Swedrone, Thanks for sharing your feedback on our service. Feel free to contact us if you have other inquiries. Have a nice day ahead!
2024-11-13
Swedrone
Sweden
I think you forgot one screenshot actually...
2024-11-17
skynetis
Flight distance : 6549 ft
Siwoo99 Posted at 11-8 03:28
+1 I hope it will be possible soon
2024-11-21
Daveb4
I'm going to throw up
2024-11-22
DJI Gamora
skynetis Posted at 11-21 01:06
Hi skynetis,
We'll voice this feedback and concern to our corresponding team.
Should you have further questions or concerns, please do not hesitate to reach us.
2024-11-23
Andrew Borg9
Malta
Hi all,
Do we know if the ham file still works on this new firmware. I've updated as i want to buy a neo, but if it breaks the ham file good bye neo and i'll downgrade again.
Anyone had the time to test this ?
Thanks
2024-12-1
Andrew Borg9
Malta
Hi all,
Thanks
2024-12-1
Andrew Borg9
Malta
Hi all,
Thanks
2024-12-1
Kyokushin
Poland
Downgrade from 01.00.0700 is possible.
HAM file still works. Safe to update.
1-11 07:32
djiuser_feYyxHK5CKQK
I need to be able to fly my fpv drone with the most current goggles. Please integrate fpv to goggles 3 or allow use of rc2 on goggles 3.
Clearly, the goggles roll out was mismatched.
Also, I’d like to fly my $4,000 Mavic 3 on them as well.
This is easy. Please just execute. We will like it and buy more things not the opposite.
1-13 13:38
skynetis
Still no news about avata 1 compatibility?
1-14 12:02
