Aardvark
Flight distance : 384432 ft
Try an IMU calibration as suggested above. Let the aircraft cool for about half an hour or so, and if you can get it a bit cooler in air conditioned room then the warm up period will reduce. Then fresh battery, and on a level surface, run IMU calibration, then restart aircraft, you should notice a difference. I would also take the time to calibrate the Gimbal, The sensors (using DJI Assistant 2), the RC (with aircraft off), and finally the compass (away from all ferrous objects).
My initialisation is about 90-120 seconds after calibrating at Room temperature last time (about 20 C).
