Goggles 3 not charging to 100%
2893 27 2024-4-19
Kesav
Flight distance : 3257641 ft
Czechia
The Goggles 3 will charge to 99% only, and charging still running. 100% is not possible to achieve. Solution?
2024-4-19
Dirty Bird
Flight distance : 41442379 ft
Use them until they run down below 50%, then try charging them again.
2024-4-19
Kesav
Czechia
Dirty Bird Posted at 4-19 07:58
Thank you for answer.  I discharged the goggles to 9% and charged them again.  The problem still persists.  I tried a different charger and cables.  I did factory reset the goggles and they also reinstalled the firmware.  No change.
2024-4-19
Dirty Bird
Kesav Posted at 4-19 08:58
My only other suggestion would be let them discharge completely until they power off, then charge them full.  If that doesn't reset the battery meter properly an exchange is your only bet.  Over the years I have had one or two DJI devices do something similar.  My Mavic 2 Pro RC never charges to 100%.  Usually 97% & charging stops.  Doesn't seem to affect the RC's total runtime.
2024-4-19
DJI Tony
Hi, Kesav. Let me check this with the relevant team. I will keep you updated. Thank you for your patience.
2024-4-20
DJI Tony
Hello there. Thank you for patiently waiting. The goggles' power level is 100% when fully charged. The issue you report is because the battery level is rounded to the nearest 1%. When Goggles 3 starts, it uses a bit of battery. Even though the consumption is less than 1%, the battery indicator won't show 100% anymore but will read as 99% instead. You can rest assured that this is normal. Have a nice day.
2024-4-20
Kesav
Czechia
DJI Tony Posted at 4-20 21:41
Thank you for answer. I would understand that. But the problem is that the charging is still going on even after about 2 hours. I don't think it might be safe or good for the battery. If there was a final charge with 99%, I have no problem. But this way I don't know when the battery is fully charged, i.e. the 99%. The LEDs keep flashing as if the battery is almost charged, 4 LEDs in sequence.
2024-4-20
DJI Tony
Kesav Posted at 4-20 23:59
I see. Will it be fine if you post a video showing the behavior? I will forward it to the designated team to confirm if this is normal. Thank you.
2024-4-21
Kesav
Czechia
After connecting to a charger that supplies only 5V, the Goggles were charged to 100% and charging was finished. Also successfully using a power bank at 9V. So I assume it fixed itself. Thank you for help.
2024-4-22
djiuser_lpCWoj49lZip
Flight distance : 1790144 ft
Poland
I do have similar problem with different chargers. Int's indicating as 99% and continue charging
UPDATE: I tried to use charger with 5V out only - completed oon 100%
2024-5-11
djiuser_emo5v19x3tyF
India
Hii my Dji Goggle 3 keeps on charging for hours and hours and when i on its still on 99% … What is the Issue plzz
2024-6-5
Owen Corpie
Same issue here with the dji goggles 3
it has never reached 100% after coming out of the box.
It keeps charging for hours.
2024-7-1
SaurabhSrivastava
Flight distance : 2380479 ft
India
Just try with a normal USB Type A charger first. It can be your old phone charger that has only USB A output.
Your best bet would be to use the charging hub of the avata 2 batteries as it outputs only 5v @ 2Amps.. See if that fixes it.
2024-7-1
DJI Natalia
Owen Corpie Posted at 7-1 10:36
Hi there,
thank you for reaching out.
We are sorry for the inconvenience. May we confirm if the battery level indicator constantly flashing on your DJI Goggles 3 when it is plugged into the charger?
Please keep us posted. Thank you.
2024-7-2
Poland
DJI Natalia Posted at 7-2 00:08
Hi there,
In my case cgarging indicator contently showing that process is going. And newer stops
2024-7-15
DJI Natalia
djiuser_lpCWoj49lZip Posted at 7-15 13:13
Thank you for getting back to us. To effectively address your issue, it would be really helpful if you could provide a video of the problem. Looking forward to your reply. Thanks.
2024-7-15
Poland
DJI Natalia Posted at 7-15 15:27
https://youtu.be/n7vhGAM35ok
Hi. Here is it
2024-7-16
DJI Natalia
djiuser_lpCWoj49lZip Posted at 7-16 03:26
Hi. Here is it
Hi there,
Thank you for reaching out.
We are checking with the relevant team on this matter with the provided information and will get back to you with an accurate answer once we have the result.
We appreciate your understanding and patience, thank you!
2024-7-16
djiuser_eJRVvoiqCvZM
Same issue… brand new avata 2. DJI - please advise, this is obviously a common issue.
2024-7-29
DJI - same exact issue. The goggles 3 will only charge to 99% when high watt charger is used for fast charging. It also will continue to blink like it’s charging indefinitely. When low watt charger is used it charges slowly but will charge all the way to 100%.  Please advise.
2024-7-31
XdekHckr
Flight distance : 1225174 ft
Poland
djiuser_eJRVvoiqCvZM Posted at 7-31 23:38
I have exactly same issue... I wil probably send it back withing 14 days for replacement, lol it's dumb. Batteries and controller are charging normally
2024-8-12
djiuser_9ZV72HxByH9b
djiuser_eJRVvoiqCvZM Posted at 7-29 21:37
Yes same issue here too. Have been sat watching blinking lights for hours!
2024-9-25
Max Phlanx
Flight distance : 1223816 ft
Same issue here. Keeps charging unless I unplug charger for a while and then try charging again. Its a very annoying bug because it just keeps showing as charging. It would be nice if we could know if this is a hardware error or a software error. Lithium Ion batteries should not show as charging forever in an endless cycle. What do we do about this DJI?
2024-9-29
djiuser_oclOeCMUP72u
I just received my goggles 3, went to charge it after a few hours realized something was off. I have the same problem. It keeps blinking for hours and never fully charges.
2024-10-29
djiuser_JCnMvFQdcjiy
United Arab Emirates
Same issue. Brand new G3, charge at 99% and keeps going.
Tried both 5v and 9v out charger with new and high quality cables.
Any fixes yet?
2024-12-11
Antdrones
Flight distance : 1253035 ft
odd, do you really need the extra 1%? if so just send it in since you probably have warranty
2024-12-11
Antdrones Posted at 12-11 14:11
It's not about the extra 1%
I'd like to know when the battery is fully charged.
If it is "full" at 99%, the charging indicator should turn off to... well, indicate that the device has finished charging.
2024-12-11
Antdrones
djiuser_JCnMvFQdcjiy Posted at 12-11 20:59
ah. send it in for warranty then
2024-12-12
