fichek
Flight distance : 1378789 ft
Croatia
Ok, I did some testing and here's the deal:
You load any h.264/265 movie file onto your goggles SD card and open it from the album normally. From the upper menu you can then switch between 2D and 3D modes.
In 2D mode you can select fov of "normal" or "panorama", which just seems to stretch the movie beyond your goggle screen fov and then lets you move your head to look around and see all parts of video.
In 3D mode you select if video is side-by-side or over-under, if it's half or full width, and if the sides need to be flipped. I found a 3D movie and it actually looks pretty good, I might actually try watching some full feature films in 3D to see if there's any eye strain. |
