The "Downward" warning?
512 9 5-5 13:24
Canada John
Hi.
I'm having a bit of trouble fully understanding the warnings that appear on the controller's screen when the drone comes close to the ground. There are two: a yellow worded warning that seems to appear when the drone is between 3 and 5 meters above the ground, and a red version that appears when the drone is below 3 meters. What I"m trying to figure is the discrepancy between the footage listed next to the Downward warning and the height/altitude listed on the main screen. I attach an example. As you can see, the screen says H 2.3 M, while the warning in red says "Downward 1.7 m.". I've been scouring tutorial videos but have not found this discussed anywhere.
Thanks.
John
5-5 13:24
Dirty Bird
Flight distance : 41442379 ft
The altitude listed beside the H is your approximate height above the point from which you lifted off.  It is relative to that point only & is an approximation based on the barometric sensor in the drone.  It is NOT your altitude above the ground.  If you lift off to 3' on the lip of the Grand Canyon then fly over the rim, the drone will still show your altitude as 3'.
The yellow/red proximity warning you see as you approach the ground is determined by the IR sensors on the bottom of the drone.  This is a close approximation of your distance from the ground or an object (roof, trees, car, etc.) directly beneath the drone.  The drone will USUALLY prevent you from flying into the ground, though it can still happen if the terrain is steep or rugged.
5-5 15:32
Canada John
Thanks for that explanation DB.
5-5 16:02
DJI Gamora
Hi, John. Thank you for reaching out. The H 2.3 M represents the height of 2.3 M relative to the take-off point, and 1.7m downward represents the detected object 1.7m away from below. The two meanings are different. However, it should be noted that there is a certain error in aircraft height detection. Even after taking off from the ground, the H height and the downward height are not necessarily exactly the same. Slight errors are normal. Hope his helps.
5-9 06:45
Dan.Kearney
Good Info.  Thanks for sharing.
5-9 15:57
DJI Gamora
Dan.Kearney Posted at 5-9 15:57
You're most welcome, Dan.Kearney. Should you need further assistance, please let us know.
5-20 07:17
Juc1
So at what heights do the yellow and red "downward" warnings trigger? Suppose I am 50m or more above a lake - can I trust that my mini 4 pro can fly close to the surface without ditching into the water?  Are these "downward" warnings for information only ie not requiring me to do anything?
5-26 05:20
Canada John
As best I can recall the red warnings are for below three meters, yellow something like three to six. The respective warnings only come on when you are those heights above the ground. Take your drone to a safe place - i.e. flat ground that you can observe - and fly your drone over it. Hover down till those warnings come on and look at the meter number that will appear beneath them. I find these readings to be very accurate.
5-26 06:09
Juc1
Ok thanks, after some testing I think it is yellow warning at 5m and red warning at 2m. As for my other question - with obstacle avoidance on, I think 0.5m might be the lowest and then it will refuse to go any lower, so it should not hit the ground. Over water such as a lake, users are more cautious about minimum height due to the risk of losing the drone in the water.
6-3 09:35
Canada John
Hi. Sounds about right. Good luck. You'll notice, too, how if you land by holding the joy stick down, as you get into that red the thing will beep away. Of course you are ignoring it becasue you have the drone right in front of you and you've positioned it over its landing pad.
6-3 10:10
