Struthio
Poland
harweyko Posted at 5-8 21:17
If it was legally possible why not, but it isn't. If your car is certified as N1 (small lorry up to 3.5t) with max weight with load of 3000kg in papers, and you load it to 3600 kg, it's not automatically N2 category truck (3.5-5t), it's just overloaded N1 category vehicle (and you can be breaking the rules as driver as N2 requires C type driver licence instedad of B typem same as A1/A3 exam for C1 drone). And the same is valid for C0 drone with plus battery, you can't recertify it between categories automatically 10 times a day.
Yes, You are right.
I just wanted to point out that enabling RID should also not take place with an extended battery, as You mention it is still a C0 drone 'overloaded', not C1 drone so RID is not required. Drone just violates C0 certification rules not recertify itself.
Second case is if C0 is violated (and You shouldn't fly such a drone), then upholding max altitude limit does not give anything - C0 is violated anyway (but I understand that larger batteries are not such a risk as flying higher and hitting some other aircraft).
Going away from DJI limits, C0 is a bit of a strange certification (at least in PL and Mini4Pro). I have a limit of 120m from take-off point, BUT I have to register any flights to authorities before I start and define the height in AGL that I will be flying. If I start a drone on the hill and fly over some valley I can easily violate rules for 'allowed flight'. |
