Avata 2 keeps loosing date....
123Next >
3893 101 2024-5-15
DAFlys
My Avata 2 keeps loosing the date, and I see on the forum that other people have reported the same,  is there some sort of best practice to ensure that the date is kept correct or a way to check the date before flying so that we can do something to correct the issue.   My workflow uses the date and time to copy and organise the footage automatically and when the date is incorrect it doesnt work correctly.
Perhaps a candidate for an up and coming firmware fix?
thanks
DA
2024-5-15
fichek
Flight distance : 1378789 ft
Croatia
Just curious if you keep one of your batteries inside the Avata 2 or you store them all in a hub? So far I've kept one in the aircraft most of the time (except when charging all 3 or using power accumulation feature) and so far my date hasn't slipped up. So just wondering if maybe it's due to battery being removed for a long time.
2024-5-15
DAFlys
fichek Posted at 5-15 09:08
I do a bit of both,   but surely the date should get updated from the fly app when the connect.    Never had any other drone loose the date when a battery wasnt in the AC overnight.
2024-5-15
Dynx
Flight distance : 176654 ft
DAFlys Posted at 5-15 21:13
GPS data contains precise date and time information, there is no need to use the Fly app.
2024-5-15
DAFlys
Dynx Posted at 5-15 21:20
Haha.  Yes thats a very good point,   but it would be nice if the drone and the goggles time was in sync.
2024-5-15
fichek
Croatia
Very true, weird that they require connecting the goggles to DJI Fly in order to fix the date when it's wrong. And it doesn't even seem to work for everyone all the time.
2024-5-15
fichek
Croatia
Most devices with swappable batteries have a smaller battery inside them to keep clock (even computer motherboards have coin cell battery on them for that reason, for when they're unplugged or power supply is off), I thought maybe Avata 2 just didn't, or had a capacitor or something that runs out too fast. I've left all my batteries in the hub since yesterday and will try to see if my time gets lost today after ~24h have passed.
But yeah, if you connect to DJI Fly, it should set the time. I've seen several reports on the forum already that it doesn't always work though.
2024-5-15
DAFlys
fichek Posted at 5-15 22:54
I pretty sure it didnt work last time I connected the goggles,  it seems to maintain time and the date slips to the last flight date,  or maybe the last date on the SD card.
2024-5-15
fichek
Croatia
DAFlys Posted at 5-15 23:08
I did notice that with Mini 3 Pro with RC - I borrowed it from a friend who hasn't used it in a while and when I first recorded something, it had the same date as his last clip! DJI definitely needs to look into these things, would be nice if they could just pick up the correct timestamp from GPS data as Dynx suggested.
2024-5-15
DAFlys
fichek Posted at 5-15 23:20
The only date issue I had with the DJI RC was it missed the leap day.
2024-5-15
fichek
Croatia
DAFlys Posted at 5-15 23:29
That's a pretty embarrassing bug to have
2024-5-15
DJI Gamora
Hi, DAFlys. We're sorry for the inconvenience. Preliminary judgment is that there is a date/time error in the Goggles. Please try to correct/calibrate the date/time. The method to calibrate is to connect the Goggles and the mobile phone through the data cable, and open DJI FLY when the mobile phone is connected to the network, thereby calibrating the time information in the Goggles. If the issue persists, please let us know.
2024-5-15
Dynx
DAFlys Posted at 5-15 21:39
They will be in sync since DJI Goggles 3 and Integra have build-in GPS module. They need it to be compliant with remote id requirements.
2024-5-16
DAFlys
Dynx Posted at 5-16 05:28
Well so far my experience has been the times do not match between drone and goggles.   Makes cutting between goggles video and avata video in post a nightmare.
2024-5-16
fichek
Croatia
Just tried after not having a battery installed in my Avata 2 for about 31 hours. Powered on the aircraft, goggles and controller, armed the motors to start recording (had 0 sattelites on Avata and probably none on Goggles either as I'm an apartment building, far from a window and far enough from last used location) so I doubt it picked the time up from GPS, but it did record correct time down to a second. I'm guessing even if Avata 2 doesn't have a small RTC battery in it, Goggles will keep RTC since they have a built-in battery and they are likely supposed to sync that clock to aircraft on every connection, but it doesn't always work (which is why DJI reps constantly suggest connecting to DJI Fly, I guess that's supposed to force the sync, but obviously doesn't work for people who have this issue). Lots of guessing here, I'm just trying to think out loud in hopes that it will help someone with debugging. I'm happy it seems to work as intended for me.
2024-5-16
DAFlys
fichek Posted at 5-16 14:34
DJI Confirmed above that there is a known issue with the goggles loosing the date/time.
2024-5-16
DAFlys
DJI Gamora Posted at 5-15 23:46
Thanks DJI Gamora,  I have done that before and it corrects the date for a fe days and then it was lost for a second time thus my question.
Is there an ETA for new firmware to correct this?
2024-5-16
fichek
Croatia
DAFlys Posted at 5-16 21:16
My understanding was that your goggles screen recordings had correct date, but onboard footage from Avata did not?
2024-5-16
DAFlys
fichek Posted at 5-16 23:59
Goggles loose time but keep the date.  Avata2 seems to default to the last thing recorded on the sd card so looses both.
2024-5-17
fichek
Croatia
DAFlys Posted at 5-17 04:45
Ooooh, I see. Thanks for clarifying. That's definitely a big inconvenience for file organisation and especially if you wanna sync up goggle recordings to onboard ones hope it gets fixed before I run into it.
2024-5-17
DJI Gamora
DAFlys Posted at 5-16 21:18
Hi, DAFlys. Thanks for the update. We currently don't have information for the next firmware update but we will forward your feedback to our relevant team.
2024-5-17
DAFlys
fichek Posted at 5-17 05:51
It would be more manageable of the file names were the old DJI_123445.xxx but now they include the date and time in the name itself even thats a pain.
2024-5-17
fichek
Croatia
DAFlys Posted at 5-17 21:29
Yeah, that one is a huge regression in the last few DJI products (seems like everything since Air 3 started breaking the old naming scheme which was actually a standard accepted by entire industry) as it breaks auto-import into video editing software too. I opened a thread trying to convince DJI that they need to fix that: https://forum.dji.com/forum.php?mod=viewthread&tid=311643
2024-5-18
DJI Gamora
Hi, DAFlys. Please check my DM regarding the topic we discussed. Thank you.
2024-5-19
DAFlys
DJI Gamora Posted at 5-19 07:14
Thank you DJI Gamora for keeping on top of this one.   I appreciate it.
2024-5-19
DJI Gamora
DAFlys Posted at 5-19 07:45
You're most welcome, DAFlys. Can you still remember when you recorded the file?
2024-5-20
DAFlys
DJI Gamora Posted at 5-20 06:44
The last time it lost the date it got stuck on the 10th May until I connected the phone again.
2024-5-20
DJI Gamora
DAFlys Posted at 5-20 07:07
Thank you for the additional information. Can you please export the goggles log and aircraft log? Also, please provide the exact date and time when the issue occurred.
2024-5-21
BrockB
Flight distance : 695335 ft
Looking forward to a fix... My files are three days off.
2024-5-21
DAFlys
BrockB Posted at 5-21 13:24
Plug your phone into the goggles and run the fly app and sync the logs and it will sync the time back to be correct.  How long it lasts for is a mystery.
2024-5-22
DAFlys
DJI Gamora Posted at 5-21 07:31
Hi Gamora,
here's a link to the first log on the avata where the time is corrected.  https://filetransfer.io/data-package/iWYDyyNd#link
It's hard to say when it occurred,  from the picture attached,  the highlighted logs have the correct date and time,   the rest from May 10 are incorrect.   The log from the 17th Is the first one after syncing the time/date as per your instructions.
I connected the goggles to DJI assistant and unlike the avata2 it was not recognised.
2024-5-22
DJI Gamora
DAFlys Posted at 5-22 00:07
Hi Gamora,
Thank you for this, DAFlys. We'll forward it to our relevant team for further checking. I'll keep you posted.
2024-5-24
DJI Gamora
Hi, BrockB. Please check to try the steps on this [url= https://forum.dji.com/forum.php? ... 392&pid=3317435]post[/url], if the issue persists, please let us know.
2024-5-24
BadBert
Flight distance : 187910 ft
I connected my phone with fly app to everything before i went on a trip, so time and date should be OK on the avata 2 and goggles 3
but afterwards i saw the date and time were not correct....
really anoying when you want to add images and video based on time taken together with footage from other drones / camera/s......
please fix this.
2024-5-26
DAFlys
BadBert Posted at 5-26 22:40
Exactly whats happening to me,   although Im now getting a new drone as I dunked mine in the sea.
2024-5-26
DJI Gamora
Hi Gamora,
Hi, DAFlys. Thank you for patiently waiting. We have now the results from the data you have provided. Feedback is as follows: Checking the user's aircraft log data. The material shooting time of DJI_0976-DJI_0981 is consistent with the data time in the aircraft log. There is no abnormality. Due to the lack of logs of DJI Goggles 3, it is not confirmed whether the aircraft time and the flight goggles time are consistent. This category Many problems are caused by the device system time and the actual network time not being synchronized. It is recommended to connect the mobile phone and DJI goggles 3 while DJI Avata 2 and DJI goggles 3 are connected and open the DJI FLY APP to synchronize the time with the Internet and test again. If the material The creation time and actual shooting time are still inconsistent. Corresponding aircraft and glasses log data, as well as actual shooting time and error display time information need to be provided for further analysis.
2024-5-29
DAFlys
DJI Gamora Posted at 5-29 07:46
Ok. So I just have to sync before each flight just to be sure the time/date is correct.   I wpuld have hoped it would keep the date/time as well as other DJI drones.
2024-5-29
BadBert
DAFlys Posted at 5-29 08:20
that would be a bit stupid... having to sync date and time before each flight.
DJI, please fix.... the drone should keep date and time itself.
The avata 2 is a drone you fly without a phone connected!
2024-6-1
DAFlys
BadBert Posted at 6-1 05:34
2024-6-1
Shadetail
Flight distance : 785125 ft
Croatia
Yeah I also have the time/date bug, my flights are time stamped with a couple of days of offset, seemingly random offset and it changes. I did some flying right now on June 1 at 5pm, and those files got tagged as May 26 7:30 pm.
It's quite annoying when trying to sort and organize multiple videos in the same folder, hope it gets fixed soon.
2024-6-1
123Next >
