Mavic Mini 1 - strange spining movement
1142 11 2024-5-15
djiuser_G6mVGfsGXlsF
Flight distance : 2038369 ft
Hungary
Hi!
What could be the reason that if I just want to rotate the drone around its z-axis, the z-axis does not stay in one place, but while rotating it also moves in a circle of about 1m diameter?
2024-5-15
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Kindly provide us a short video showing the issue so we can check it further. You may upload the video via Google Drive and send the link here. Please keep us posted.
2024-5-16
Hungary
DJI Paladin Posted at 5-16 04:23
Hi!
I uploaded 2 videos here:
https://drive.google.com/drive/folders/1DvbHuctAq9QmsGsMcB8Fu-nl19Pu6Hwg
2024-5-16
Sean-bumble-bee
Flight distance : 15997 ft
Three suggestions.
1) calibrate the controller and pay attention to what the animations show.
Prior to calibration is the aileron showing any applied stick ?
Fly a test flight after the calibration has been done.
2) Calibrate the IMU.
3) repeat the flights with a phone attached to the controller then upload the .text flight log/s for those flights to phantom help's log viewer and post the resulting URLs here. Also, switch off syncing with DJI and upload the DAT flight log to a file hosting website, make the page public and post the URL here.
Some movement is normal but what you show is unusual.
2024-5-16
Hungary
Sean-bumble-bee Posted at 5-16 12:46
Three suggestions.
Thanks for the suggestions!
I did the first one before the videos, and I was also wondering if the right jostick before calibration would show a deviation from 0 in the default position, but it didn't.
I will try the others.
2024-5-16
DJI Paladin
djiuser_G6mVGfsGXlsF Posted at 5-16 10:24
Hi!
Thank you for the information provided and we do apologize for the trouble. Kindly please calibrate the IMU and the remote controller via the DJI Fly App to further isolate the issue. In addition, please confirm if the drone experienced a hard landing before. We will wait for your response.
2024-5-16
Hungary
DJI Paladin Posted at 5-16 20:53
The next step will be a full calibration.
I don’t know the history of the previous owner of the drone. I had an accident, after which I had to replace the gimbal cables, BUT it has this weird movement even before the accident!
2024-5-16
Sean-bumble-bee
djiuser_G6mVGfsGXlsF Posted at 5-16 21:02
I don't know if it still happens but the mini used to record a READABLE  DAT on the mSD card in the drone. From memory it was found in the MISC folder or one of its sub folders. The files name is/was fc.log.log, it is/was enormous, 512mb. If you can find the log post the story over on the mavicpilots forum, upload that log to a file hosting website and include a link to the fc.log.log file in your post. Some people there may look at the log for you.
I haven't looked to see if  an up to date mini still records that file nor have I looked to see if it is still readable but if it does and is readable, a copy of it should contain the DAT/s of the shown flights.
Alternatively you could download CsvView and process the fc.log.log with it,l but you should copy the fc.log.log file to another location and the change the copy's name to fc.log.DAT before you process it with CsvView.
2024-5-16
Hungary
Thank you all for your helpful attitude!
The problem is solved! Unfortunately due to my incompetence, when I bought it second hand, I assumed that all calibrations were done. After installing the app, it only asked for compass calibration on first use.
I have now done the IMU calibration and it rotates perfectly!
Thanks again!
2024-5-17
K6CCC
Flight distance : 651683 ft
Good news!
2024-5-17
Sean-bumble-bee
djiuser_G6mVGfsGXlsF Posted at 5-17 02:42
Pleased it is sorted.
Be aware that if you fly it without a phone connected and or without the app running on that phone and or the app being logged into your DJI account, the drone's range and height will be severely limited.
2024-5-17
DJI Paladin
Thank you for keeping us posted. We're glad that you managed to isolate the issue after the calibration. Feel free to contact us if you have other inquiries. Happy flying!
2024-5-18
