DJI GOGGLES 3 wrong date?
1803 13 2024-5-19
GeorgeFoxCinematography
Flight distance : 38942690 ft
Cyprus
Hi all,
I noticed that for some reason the date(flight log) in my Goggles 3 is wrong. For example i made a flight this morning and the log instead of 19/05 shows 18/05. I connected the goggles to my mobile phone but again the date is not correct. Any ideas?
Thanks in advance,
Georgr
2024-5-19
DJI Gamora
Hi, GeorgeFoxCinematography. We're sorry for the inconvenience. Please try to correct/calibrate the date/time. The method to calibrate is to connect the Goggles and the mobile phone through the data cable, and open DJI FLY when the mobile phone is connected to the network, thereby calibrating the time information in the Goggles. If the issue persists, please let us know.
2024-5-19
Dirty Bird
Flight distance : 41442379 ft
I am not sure why the date is incorrect, but the Goggles 3 has a GPS which provides date & time data.  There should be no need to connect the goggles to a phone to obtain or update this information.  Simply powering them on long enough to establish a GPS lock should update the internal clock.
2024-5-19
AlSo-Fotografie
Flight distance : 644341 ft
I still have this problem!
From time to time ive to connect the phone to the goggles.
Then it works for some days.
2024-5-19
DJI Paladin
Flight distance : 318 ft
AlSo-Fotografie Posted at 5-19 02:58
Hi there. We do apologize for the trouble. Kindly try to refresh the firmware of your Goggles using the DJI Assistant 2 and check if the issue persists. To calibrate the date/time, please refer to the response of DJI Gamora on post #2. Hope this helps.
2024-5-19
DAFlys
Mine are doing the same,  connecting a phone with an internet connection resets it,  but it may loose it again after a few days.
2024-5-20
Dirty Bird Posted at 5-19 01:50
Yeah it fixed it self after a couple of flights. Done nothing, thanks
2024-5-29
DAFlys Posted at 5-20 01:19
I guess if you connecting it every now and then to upload your flights ,it will be ok.
2024-5-29
DAFlys
GeorgeFoxCinematography Posted at 5-29 03:26
It can loose it overnight so not really.
2024-5-29
DAFlys Posted at 5-29 03:47
Thanks very much!
2024-6-18
BadBert
Flight distance : 187910 ft
the only way to make sure the date and time is correct is to connect your phone to the goggles before EVERY FLIGHT....
i tested and noticed that sometimes it even looses the date after not flying for 2 hours (on the same day).... you would think the time would be off by 2 hours in the worst case here, but no.... the date was also set to the same date it had BEFORE i connected my phone to it the previous flight.
refreshed ALL firmware of ALL components multiple times now.
this is getting really anoying, it is pretty impossible to sync footage like this.
this is a drone you use WITHOUT a phone, it has al the hardware on board to get date and time automatically (just set the correct time zone once via goggles or syncing to a phone with DJI fly app ONCE should be enough!!!!
The whole thing about not having to use your phone means you can get in the air FAST if you see an opportunity for a nice shot... but no... you first have to connect your phone
DJI, please fix this.
2024-6-20
DJI Natalia
BadBert Posted at 6-20 22:18
Hi there, thank you for your response and we do apologize for the inconvenience caused. We will consider this as a suggestion. Your valuable feedback will be promptly forwarded to the relevant team for a thorough evaluation. We would like to assure you that we are committed to providing the best user experience.
Thank you for your continued support.
2024-6-21
fans7f5bafad
Flight distance : 16923 ft
DJI Natalia Posted at 2024-6-21 03:29
This still seems to be a problem for me, when will this be worked on?
2-25 14:07
DJI Gamora
fans7f5bafad Posted at 2-25 14:07
Hello fans7f5bafad. Thank you for letting us know your concern. Please be advised that any changes will take some time to review. We appreciate your patience and understanding during this process. Your feedback has been noted and will be passed along to the relevant departments. Rest assured, we take all customer feedback seriously and use it to continuously improve our products and services. Please stay tuned for the latest updates on our official DJI website www.dji.com. We truly appreciate your understanding and support!
2-25 14:36
