Hummingbird.UAV
![](https://forum44.djicdn.com/data/attachment/common/c8/common_2_usergroup_icon.png) Core User of DJI
Flight distance : 27489951 ft
You need to turn on photo saving in Panorama mode. Sadly you can only access the settings while the drone is flying.So take off, set the photo mode to Panorama, then tap the 3 dots in the top right of the screen. Select the type of image format you want to save.
This will now make a panorama folder on the drone's microSD card which contains the 35 images.
