Action 4: Fix for moving image issue
750 14 5-29 01:21
Grand Canyon
Hi,
I am new to this forum and a long time DJI product user.  I run into this challenge with my Osmo Action 4 and hope you can help. I searched the forum and online, without luck. Any suggestions and tips are very welcome.
Situation and challenge
  • I mount my Osmo Action 4 to a moving object (bike, car)
  • I set up a certain framing when I start
  • Then when I film on the move (bike, car) and come to a standstill the camera image (not the camera) moves the full frame of the picture down, evey single time
  • It’s very obvious when watching the footage. See the sample video:  https://youtu.be/zqpVVOPRa0E
  • Then, when I start moving again, it goes back to the original framing that I choose at the start.
Tested settings
  • This happens in Rocksteady, Rocksteady+ and Horizon balance
  • It happens both at 60 and 50FPS
  • I have updated the camera to the latest firmware
  • I have exhausted my own creativity in switching settings on and off
  • It’s not the mount that is moving. It happens in any environment/weather condition
As you can imagine it makes that part of the footage useless, or at least demands a lot of post editing.
Questions:
  • Does anyone recognize this camera behavior?
  • Is there a setting I am overlooking?
  • Is the camera defect?
  • Do I just need to deal with this?
Suggestion and tips are very welcome.
Thanks
5-29 01:21
johansenfoto
Flight distance : 1180089 ft
Norway
I think it could be the stabilization, right before it did a jump (that is normal) so it adjust itself a bit and too far down again.
You record in 16:9 or 4:3?
5-29 11:57
Grand Canyon
Thank you for the reply. This was recorded in 16:9. I tested it in 4:3 as well, with the same result.
I see what you mean in the sample video.
It happens ever single time when I come to a stop (for example at a stop sign or a trafiic light).  And also when I try to do it very slowly. In those situations it feels it only drops, without a jump. But maybe I am wrong.
5-29 22:46
johansenfoto
Norway
Grand Canyon Posted at 5-29 22:46
Just wait for DJI to reply to this, then they will have an answer.
But have you tried if it happen while walking or just panning/tilting while standing too?
5-30 01:13
Grand Canyon
johansenfoto Posted at 5-30 01:13
Thanks! I will wait for DJI to reply.
It doesn't happen when walking, panning or tilting.  It's " only"  in this specific scenario, yet every single time Which makes the footage look very amateurish and therefore useless.
5-30 01:39
Fishycomics
could be the Gyro.  when I go to reach for my camera, it's on the move already.  I gotten used to this and I try not to let it bother me anymore.. hope DJI can pass this to the team for a real answer good luck.
Regards FISH
5-30 04:12
Anonymous
5-30 10:24
johansenfoto
Norway
True it could have something to do with the gyro, try to calibrate it on a flat surface.
5-30 11:09
Fishycomics
To narrow down the issue; try turning off all EIS, and  use wide FOV d onot use the dwarp, and see if that wondering goes away.  As noted  by Johensenfoto, you may try a calibration, and noted by Osmonauta, of the earlier thread of the latter model.. Personally I sat dow nthe Pocket 3 and it as well adjusted the Horizon. I should have   shown the  file but its in my vlog instead enjoy
5-31 03:22
Andreas Dueck
Switzerland
The only way to stop this is to turn off image stabilization. During the braking process, the gyro sensor is influenced by the G forces that arise during braking. This behavior is also a problem with long curves, recognizable by a tilting horizon (in the opposite direction). DJI hasn't implemented a solution to this problem yet... maybe they can do it in the Osmo Action 5.
5-31 03:50
Grand Canyon
Excellent feedback so far. I will definitely read and try the tips mentioned above.
Andreas, I totally get your point, although that stabilization, of course, is one of the charms of the camera. It’s interesting how sensitive the gyro sensor/software supposedly is. Thanks!
5-31 04:06
Grand Canyon
Thanks again for the feedback. I have tried all of your tips last weekend. Unfortunately without luck.
@DJI: Would you be able to also look in to this and/or take it back to the Osmo Action development team as feedback. Thanks
6-3 06:35
Grand Canyon
6-19 11:00
Fishycomics
as the Gryo can be  adjusted only By DJI,  they made  Off, RS, RS+ and HB,  if you  want to go into the lower resolution and use HB/ full HB in a lower res. give them a shot, DJI will they correct,    think not
6-19 11:43
jbrujah
Andreas Dueck Posted at 5-31 03:50
I think I am seeing this behavior when leaning with my motorcycle for longer. I see slight angle adjustments every now and then. It kinda'f sucks and funny thing is, I don't remember seeing this before, so either it's because of some video setting I messed with that negatively influences the EIS or it's something that started happening after a firmware update.
9-1 13:05
