Charger for Mavic 2 pro batteries
518 13 2024-6-5
Uilleann Drone 1
Flight distance : 1127815 ft
Hi, I have the fly more combo, with 4 batteries, and I just bought 2 extra for my Mavic 2 Pro. I'd like to get an extra charger, but the DJI it does not exist in the official page anymore.
Would you be so kind to telling me an aftermarket charger that at least be able to charge 2 batteries for my dron? Aliexpress is my friend, but a bit scary of the batteries. Any advice or link?
Kindest regards
2024-6-5
Sean-bumble-bee
Flight distance : 15997 ft
I have the likes of this, so far no complaints.
https://www.ebay.co.uk/itm/404395640927
Then there is eBay for a second hand dji charger sold in the ,"used" category ?
2024-6-5
Uilleann Drone 1
Sean-bumble-bee Posted at 6-5 06:45
Thank you Sean! I have seen that charger in Aliexpress. Hope be fine to our batteries.Also, looking for an "official" second one is also a good idea.
2024-6-5
Sean-bumble-bee
Uilleann Drone 1 Posted at 6-5 06:50
The after market charger seems to appear under many company names, I suspect they are made by one company and labelled by companiew that buy them and then resell them.
2024-6-5
Dirty Bird
Flight distance : 41442379 ft
Here is a nifty Hanatora model that can charge up to 4 Mavic 2 batteries concurrently, plus the RC & your phone.  Will fully charge 4 Mavic 2 batteries in ~120 minutes.  Display shows charge status, voltage, & current for each flight battery.  Also offers 60% storage charge mode.  $57.99 on Amazon USA.
Hanatora Mavic 2 Charger
2024-6-5
Uilleann Drone 1
Dirty Bird Posted at 6-5 13:28
Thank u. That’s fantastic! But don't you think charging in 2 hours could damage the batteries?
2024-6-5
Dirty Bird
Uilleann Drone 1 Posted at 6-5 13:32
It will not damage the batteries.  It charges all 4 batteries at 2 amps each.  It just charges all 4 at once instead of one at a time like the stock charger.
2024-6-5
Uilleann Drone 1
Dirty Bird Posted at 6-5 13:36
Great to know! Thank you very much.
2024-6-5
Dirty Bird
Uilleann Drone 1 Posted at 6-5 13:48
Something to put you at ease about aftermarket chargers.  DJI batteries are "smart" batteries.  Each battery contains an internal BMS (battery management system).  The BMS monitors the battery for faults & regulates/controls the charging.  The external charger is simply a power supply.  I have used aftermarket chargers since the Phantom 2 days without issue.  The best part is the concurrent charging that charges four batteries in the time normally required to charge one.  The display & storage level charge offered by the Hanatora are two more benefits.
2024-6-5
Uilleann Drone 1
Dirty Bird Posted at 6-5 15:04
Thank you so much for yout words. I have checked that model here in Spain, as Amazon dones not send from USA up to here. Amazon Spain does not have that but I’ve got it (with different brand). Looking forward to a 120min wait instead 240…
2024-6-5
Uilleann Drone 1
Thank you so much for yout words. I have checked that model here in Spain, as Amazon does not send from USA up to here. Amazon Spain does not have that but I’ve got it (with different brand). Looking forward to a 120min wait instead 240…
2024-6-6
DJI Natalia
Hi there,
We apologize for the inconvenience. While you can purchase accessories from any third-party shop,  be sure to check for voltage compatibility. The DJI Mavic 2 Pro is only compatible with a 60W power adapter.
If you have any other questions, kindly let us know. Thank You!
2024-6-6
Uilleann Drone 1
Thank u Natalia.
This is what I’ve bought:
https://a.aliexpress.com/_EwCKJyb
2024-6-6
DJI Natalia
Uilleann Drone 1 Posted at 6-6 01:49
Thank u Natalia.
Hi there, thank you for the link shared. Upon checking we're showing that for Mavic 2 series, the charger and AC power cable needed to be used together. From the link you've shared above, I can see the charher you've purchased is compatible as it's also included with the AC power cable.
Thank you for your support!
2024-6-7
