learning starts with reading the manuals
382 1 2024-6-8
atez
The first attempt to test the mini pro 4 was a bit of a downer, You can autostart indoor only to see the drone flying full speed into a wall, maybe this should be locked without GPS signal, btw the avata 2 does the same, slow learner....
Flying the mini 4 is as easy as it gets, the biggest scare to overcome was the fact that you send the  machine far away from you. Trust in the machine comes slowly but builds with every flight.
More direct fun I get from the avata 2, the goggles 3 is a mighty awasome extra. clear and smooth video. You best sit down if you fligh low and fast, the imagery can make you sway on your feet as sight and balance do not correspond. The guards are great and give massive confidence. just remember with wich drone you fly as the avata and mini 4 can be controlled with the goggles.
Speedy charging and automatic home function complete the experience of these fabulous drones. Be brave and turn of the controller to see the drone come home (check settings first) like a faithful fourlegger. best buy ever.
2024-6-8
DowntownRDB
Flight distance : ****
Congrats on getting the Mini 4 Pro and the Avata 2.  No doubt you are going to have some fun this summer.
2024-6-9
