FreschVegables
Flight distance : 28104 ft
Hey everyone. I just got a pair of Integra goggles. They turned on and operated normally until I updated the firmware to v01.06.0000 At that point I started to get the same error as the original poster, low battery level, and battery temperature too low. Then the goggles shut themselves down quickly after. The battery level shows at least 99%, however. The ambient temperature is also not cold at all.
I would try to revert the firmware back to an older version, but the goggles do not stay powered long enough for that. The only way I am able to turn on the goggles is if a USB C cable is connected to a computer from the goggles. They do not power on any other time. They do not power on or charge with a regular USB C power outlet. Instead when the power button is pressed, a single green light flashes 3 times and nothing else.
I am not sure anyone actually provided a fix for this, not including tearing the battery compartment open and doing electronics works which is ridiculous and should not have to be solution. |
