DJI Natalia
Hi there, thank you for reaching out. May I confirm if you're checking on the stabilization of DJi Mavic 2 pro which is a 3-axis stabilization? The mechanical range of the gimbal will be as below :
Tilt : -135-45 degrees
pan : -100 - 100 degrees
Meanwhile for controllable range, it will be
Tilt : -90 - 30 degrees
Pan : -75 - 75 degrees
if there's any further inquiry, kindly contact us back. Thank you fr your support! |
