MrMarkLV
After several hours of frustration trying to get the Mimo app to connect with my Osmo Pocket 3, I gave up. I tried everything other frustrated DJI owners said to try without luck. So I walked away for a few hours. Coming back refreshed, I was determined to get it to work, and I finally did. (Galaxy 4 fold (Android)).
Maybe this will help some of the others who are having the same issue.
FYI: I will stand by all my previous posts about the App and DJI's refusal to fix an issue they had had with their App for at least the past seven years. That's when I bought my first DJI Drone. The connection issue from a badly coded app is frustrating and should have been solved years ago!
We are in 2024, not 1990. People are more on the move and mobile now than ever. Many of us use our phones for our work and our lives. I have several Bluetooth devices working simultaneously and several apps using my phone's Wi-Fi. And they do it flawlessly and without problems. I turn them on, and they work.
However, I needed to turn everything off so the DJI app could connect. The trick was that it only connected when DJI Mimo was the only app looking for your device, and it needed both Bluetooth and Wi-Fi simultaneously.
I needed to dig deeper into my settings and connections to turn off EVERYTHING. Even then, the app will often disconnect, and you must repeat what you did before reconnecting.
The issue for me was that I always use several apps on Bluetooth and Wi-Fi. They are always on and part of how my phone operates daily, and I have never really thought about them (because they work when needed).
For this, I turned off Wi-Fi searching and closed out any possible Wi-Fi sources that may want to connect to my phone. All the possible connections had to be "ignored," deleted, or turned off.
I have never had to do this with any other well-built, modern app, and I did the same with my Bluetooth and turned everything off.. On the good side, I turned off a few devices I haven't used in a while, but they still pop up every now and then and want to connect automatically without any problem. Imagine that, an app that works without any fuss!
I also had to make sure the phone and the Osmo Pocket 3 were next to each other, like touching. Any further away than about six inches, and it would not connect.
Yes, I am still frustrated at the work and wasted time I went through to get a simple app to connect to a device, especially since this issue is so old and, from reading other posts, continuous. I am also frustrated that even after it connects, if the wind blows in the wrong direction or for some other silly reason, the app disconnects and needs to be reconnected.
For the love of good marketing, DJI, PLEASE fix this issue in this decade!
Or at least give us a way to make updates that don't involve the app. Once I did the update and played around a little, I saw very few reasons I will need to use the app.
