DJI Mic 2 receiver locked
561 7 6-22 16:32
Jair Fonseca
Flight distance : 17395 ft
Colombia
Hello,I have a big problem with my DJI Mic 2 Receiver, I was updating the firmware and now it doesn't work, it freezes in the update process as you can see in the following photo
After a while this other message appears informing that the update could not be done, but when I restart the same thing happens again
I also can't see the normal screen with the menu, when I turn on the Receiver the Update screen immediately appears and I can't use the receiver
I have already tried to connect the receiver to my computer, it detects it, I copy the .bin file with the firmware again, but there is no solution, the same thing keeps happening
Does anyone know what can I do? At this moment my receiver is unusable.
Thanks in advance
6-22 16:32
DJI Susan
Hello. You can delete the firmware first, then restart it to check for new versions for upgrade.
Please keep us updated if the issue persists.
6-22 18:22
Jair Fonseca
DJI Susan Posted at 6-22 18:22
Every time I reconnect the receiver to my computer the folder is empty and I cannot delete the firmware for that reason, the file is not hidden either, there are simply no files, the problem still persists. And if I paste the firmware file, what I reported in the first message happens again Thanks for your answer
6-22 21:33
DJI Susan
Jair Fonseca Posted at 6-22 21:33
Hello. You can try formatting and then upgrading the firmware.
6-22 23:07
Jair Fonseca
Colombia
DJI Susan Posted at 6-22 23:07
I can't format because I don't have access to the receiver's menu, it is blocked and does not advance, the screen is frozen on "updating"
6-22 23:11
DJI Susan
Jair Fonseca Posted at 6-22 23:11
Hello. You can force restart and see if you can upgrade to the latest firmware. If the problem still exists, it is recommended that you send it back for further diagnosis.
Here is the link: https://repair.dji.com/gb/repair/index
6-23 00:03
Jair Fonseca
Colombia
DJI Susan Posted at 6-23 00:03
Hello, I have already forced the restart many times and it still doesn't work.
The only solution is to send the receiver back? I am in Colombia and shipping to the United States is expensive. Thanks
6-29 11:44
DJI Thor
Flight distance : 13602 ft
Jair Fonseca Posted at 6-29 11:44
Hi there, if the issue still persists, it is suggested to send in the device and check. You could contact with the local authorized service center. Here you could check the details, thanks. https://www.dji.com/service/repair/centers
6-29 22:54
