Labroides
Flight distance : 9991457 ft
Nova_EC Posted at 6-24 04:45
Hi Sean, glad you enjoyed it. I used way points because it was farly dark at the time and hard to judge how close I was to the boats and water. In the manual it also talks about not being to close to metal objects, buildings with rebar etc could effect the performance. Presumably this effects the compass?
There's nothing at all wrong with flying over water.
Using waypoints to fly close to obstacles is always risky and should be avoided.
The water surface is a big obstacle.
Don't do that.
First .. forget about "metal".
Steel or iron is what you need to be concerned about, not brass, copper, aluminium, zinc etc, etc.
Second .. what you are close to makes no difference.
What's close to the drone when you power up can make a difference. |
