Can O3 Air Unit sync flights to DJI Fly App flight log?
691 4 2024-6-29
ro_walker
Brazil
2024-6-29
ro_walker
Brazil
Anyone?
2024-8-15
ro_walker
Brazil
3-9 16:43
DJI Gamora
Hi there, we truly apologize for the inconvenience and delay. It is recommended to try the below path.
1. Launch the DJI Fly app and enter the home screen. Tap “Profile > More > Flight Data”.
2. When “Auto-Sync Flight Records” is not enabled, a prompt will appear stating whether to enable this function after entering this page. Please tap “Enable” to finish synchronization of flight records.
3.  If the prompt is canceled, you can check whether quick “Enable” is displayed on the top of the same page or enter the DJI Fly home page. Tap “Profile > Settings > Sync Flight Data > Auto-Sync Flight Records” and tap “Enable”.
When the aircraft is used together with goggles
1. Please make sure that the DJI Fly app is version V1.3.0 and above;
2. Follow the steps below to connect the goggles to the DJI Fly app:
Method 1: Connect the DJI FPV Goggles V2 to a smartphone via an OTG cable and a Type-C or Lightning cable.
Method 2: Connect the DJI FPV Goggles V2 to a smartphone via a Type-C to Type-C PD Cable or Type-C to Lightning cable.
3. Launch the DJI Fly app and enter the home screen. Tap “Profile > More > Flight Data”.
4. When “Auto-Sync Flight Records” is not enabled, a prompt will appear stating whether to enable this function after entering this page. Please tap “Enable” to finish synchronization of flight records.
5.  If the prompt is canceled, you can check whether quick “Enable” is displayed on the top of the same page or enter the DJI Fly home page. Tap “Profile > Settings > Sync Flight Data > Auto-Sync Flight Records” and tap “Enable”.
3-9 19:23
ro_walker
Brazil
tks !!!!!!!!!!
3-11 21:15
