BadBert
Flight distance : 187910 ft
Khemon Posted at 7-3 13:49
I don't see any point in this. The company should fix all the problems in the product first. Only then add something. After all, resources are not unlimited.
The camera is only good for 2024, when competitors are at the same level. When DJI releases their new action camera, or gopro or insta does... Avata will no longer be the best quality camera.
But that's not what I'm talking about. If you want to take high-quality photographs, you should use x9 50mm
the fact YOU don't, does noet mean others also should not see the benifit in this.
the camera of the A2 is good enough to make usable photo's, i own a mini 2 and avata 2, and often shoot photo's with the avata 2 because i have it in the air at that time and these photo's are as good as the mini 2 photo's, and the mini 2 has the raw option.
So if you are used to that, and aplying your own filters, i can understand you would like this to be possible on the Avata 2 as the camera is more than good enough (and way better compared to the avata 1) |
