Avata 2 battery hub charger
1377 14 2024-7-3
sysprep
Flight distance : 718990 ft
Argentina
Hi, has someone tried the 65w official charger with the battery hub? In a topic i have read that 65w car charger isnt working. Just wanna be sure before purchasing it. Thanks!
2024-7-3
SaurabhSrivastava
Flight distance : 2380479 ft
India
Works like a charm. I have the original DJI 65w CAR CHARGER and 100w desktop charger. BOTH work absolutely fine.
2024-7-3
sysprep
Argentina
SaurabhSrivastava Posted at 7-3 17:00
confirm me you are using it to charge avata 2 hub, your profile shows you are using avata 1. just to be sure. thanks
2024-7-3
DJI Natalia
Hi there, thank you for reaching out. You can absolutely use the 65w official charger with the battery hub with no issues. The charging hub supports max 65W and you can find this information under " specs " on the official website.
Thank you for your support and understanding.
2024-7-4
SaurabhSrivastava
India
sysprep Posted at 7-3 18:04
I have Avata 1 and 2 both. Both hubs work with those chargers.
2024-7-4
sysprep
Argentina
DJI Natalia Posted at 7-4 02:05
Tried with many chargers and didnt work. Tried a HP Probook 440 G8 USB-C port (rated at 65w) and didint work. Also tried a 65W samsung wall charger and didnt work. Finally i bought oficial DJI wall charger, it will arrive on saturday.
2024-7-4
DJI Natalia
sysprep Posted at 7-4 10:47
Hi there. Thank you for your response. Please try the original DJI wall charger and cable as you mentioned and see if this issue persist. If so , please get back to us for more support.
2024-7-4
Swedrone
Flight distance : 15419022 ft
Sweden
Something like this would work just as fine
https://www.amazon.com/AnHome-65 ... ible/dp/B0C9YHHYNJ/
2024-7-4
DJI Natalia
Swedrone Posted at 7-4 12:07
[view_image]
Hello there! Thank you for sharing the information, and we sincerely appreciate your effort in providing us with the necessary details for both our team and the fellow users. Your contributions are highly valued.
Keep us posted always. Thank you for your continued support!
2024-7-5
designrs
I’ve had good success with the Avata 2 and this charging brick:
https://www.amazon.com/dp/B0CZCR83BP?ref=ppx_yo2ov_dt_b_product_details&th=1
2024-7-9
OldGuy2024
Flight distance : 632428 ft
Using couple different charging blocks. Anker Nano II 65w single port and generic amazon purchased 3 port (2 usb-c, 1 usb-a) 128 watt unit. The 3 port model notes max of 65watt from the top USB-C port, 45 watt from the middle USB-C port and 18 watts from the USB-A port if using all ports simutaneously. Otherwise 65 watts from any of the 3 ports if only one is in use. Both the generic and Anker based on power meter readings max out at +50 watts(IIRC 58 watts max), not 65 watts. The 3 port generics are priced from the upper $20 to mid $30 price range.  Works fine if needing to charge batteries, goggles, and controller at the same time.  Multiple different look alike models available at AMZ.
Higher power is nice when the battery is at low capacity. Eventually the charging profile of the "smart battery" or charger ramps down the wattage. I think both charging blocks claim to be PD 3.0
2024-7-9
DJI Natalia
designrs Posted at 7-9 08:21
Hello there, thank you for the updates and we're glad that these information worked for you. Do not hesitate to contact us if there's any additional inquiry.
2024-7-10
DJI Natalia
OldGuy2024 Posted at 7-9 19:21
Hi there, thank you for sharing these information here with our fellow users.  We genuinely appreciate your generosity in sharing valuable information with others and your effort.
Keep us posted always and thank you for your valued support!
2024-7-10
Ilias_SA
Flight distance : 158291 ft
Russia
I charged using a Baseus power bank and GaN with 65W and 100W chargers. Everything is fine
2024-7-14
SgtRay
Flight distance : 15007251 ft
I use my Ecoflow Pro. It has a 100W C. It works fine and with the other 3 USB (2 USB-A 1 USB 3.0 fast charge) work well to charge the rest while that's going on.
2024-7-15
