DJI MINI SE unable to connect to the controller
479 3 2024-7-3
djiuser_NllO5NpqIHvY
Flight distance : 68871 ft
Hello there,
Im having the same connection problem with my Mini SE , and did the instruction to update via DJI assistant to refresh the firmware to 100%, however, it's having the same problem to connect to my controller. I have two MR1SS5 controllers and tried two iPhones and two lightning cables still having problem.. please help.   The drone was working fine before, however, suddenly not able to connect
2024-7-3
DJI Natalia
Hi there,
Please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-7-4
DJI Natalia Posted at 7-4 01:52
Hi there,
Thanks for your reply. Im able to connect to the controller now.   What I did was holding all three buttons on controller by following this post at Reddit
2024-7-4
DJI Natalia
djiuser_NllO5NpqIHvY Posted at 7-4 05:53
Hi there,
thank you for reaching out.
We are glad that it worked out for you. We appreciate the feedback given to us.
Should you have any other inquiries, kindly message us here for assistance. Thank you.
2024-7-4
