DJI Natalia
Hello, this warning is to ensure safe flight because the aircraft has detected that the propellers have been misshapen or seriously damaged. We recommend that you prevent the propellers from being squeezed by the carrying bag. This issue is more likely to occur when the rear motor propellers are stored. Meanwhile, misshapen propellers may not be visibly detected. However, misshapen propellers will affect flight safety due to loss of propulsion, in particular on the aircraft’s wind resistance. When propellers are not seriously misshapen, you can hover your aircraft in a safe position. Then, the motor will try to correct the misshapen propellers, and land the aircraft. Let the aircraft stand still for several minutes and restart the aircraft. If there is no prompt, this indicates that the misshapen propellers have been corrected. In future usage, please store your aircraft properly and prevent the propellers from being squeezed. Thank you for your understanding. |
