DJI Natalia
BadBert Posted at 7-5 02:41
Yes i found my drone, but i think you have misunderstood my post.
It had updated the homepoint on takeoff (more than enough sattelites), but i had to use turtle mode to get it to flip back on its feet because i had a "crash" (really soft landing, just unfortunate and it landed upside down no damage whatsoever drone is perfectly fine), when i used turtle mode and took off again (aprox 300 meters away from me), homepoint updated again (automatically!!!) and so when i lost signal shortly after that, it returned to home, but that was the location where i did the "turtle mode recovery", and this was not the take-off location i started.... so after a recovery with turtle mode, RTH is useless and dangerous because you can lose your drone like this.
Hi there,
Thank you for keeping us posted. We're glad you got back your drone safe.
The purpose "Turtle Mode" is for when a drone crashes, falls off, and turns over on the ground, the pilot can operate the drone to flip on the ground. Therefore, it is unnecessary for the pilot to run a long way to flip the drone manually. The Turtle mode on DJI Avata 2 should not be the reason RTH location changed. GNSS signal weak at the area it fell or the drone could have restarted after the fall which might change the homepoint location. Hence we suggest you to try in different location and let us know if the same issue reoccur.
We are looking forward to your response for further assistance. Thank You |
