DJI Thor
Flight distance : 13602 ft
Hello easy peazy, after checking with our engineer, we would like to conduct additional tests to determine if the same issue occurs after replacing different batteries or slots. If the issue persists, it is likely that there is a problem with the battery box control board. In this case, we recommend sending it back for further diagnosis. Thanks.
