Formatting SD card and transfer files to Windows
franksstudio
Flight distance : 13540 ft
Subject re-posted in https://forum.dji.com/forum.php?mod=viewthread&tid=314895
2024-7-8
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2024-7-9
franksstudio
DAFlys Posted at 7-9 02:58
Ok I will go there thanks.
2024-7-9
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
If you need to export to your computer, kindly follow these steps below.
Method 1: Device and computer connection export
1. Turn on the device, use the data cable to connect to the computer through the USB-C port (charging port) on the side of the camera.
2. A prompt will appear on the camera interface of the device, please select "File Transfer/OTG".
3. Open the SD card disk on your computer, find the "DCIM" folder, and copy out the required videos/photos.
Method 2: Export via card reader
- Remove the SD card from the camera and insert it into the card reader, then connect the card reader to your computer to export.
For a detailed step-by-step guide, you can also refer to this article: https://support.dji.com/help/con ... ;paperDocType=paper
Should you have any other questions, kindly message us for assistance. Thank you.
2024-7-10
