Iancraig10
I’ve had another play around with 4:3 today and have found ……
Astonishingly good straight lines on ultra wide. (As well as the others)
Proportions really look very normal, like a decent lens with less pulling at the edges.
The software that I’m using deals with picture size in an odd way, but I can set it to the proportions of the 4:3 on a 16:9 timeline and it forces the picture to fit. Then I’m able to scroll up and down.
Fish, if you’re watching …. I know that you use this same programme as me …. Try this. Lines and proportions really aren’t action cam like ……
I’m using Movie Studio 2024.
Set format of move to 16:9, 4K,
Import 4:3 material drag to timeline.
Don’t adjust when it asks, make the programme fit the square format to 16:9 (click ‘do not adjust)
The picture is stretched left/right so ……
Click Effects, Size Position and apply
A red dot appears in centre of preview …. For now leave it there.
Click so that ‘Combine input fields is disabled’ in settings in adjustments (no tick in the box).
Adjust height to 2880. (The width of the 4:3 footage)
The picture is the correct size.
You can move up and down by using the arrow keys in the square box so that you get the view that you want, or you can type in the amount manually for small adjustments, but the distortion is massively less!
In this Jpeg (Excuse mess, we're getting ready for Florida) I took this video shot in Ultrawide, 4:3 format and there are no adjustments whatsover for bending back of straight lines!!! It looks like a 'normal' camera and proprtions are really good. As Roger said, you now have the full sensor width of 2880 pixels being used and the choice of up and down viewing with what looks like less bending than you get in widescreen mode.....
In the garden shot below, the fence on the right shows less bending than the shot I did up above and trimmed of the same thing and looks way more 'normal' to me. This was also in ultra wide. I think in Florida, I will be using 4:3 quite a lot after playing around with this. The full 2880 wide pixels are being used. No cropping so there is also room to slightly crop in with no loss at 4K. You also get a slightly wider fov with less lens distortions.
Fish, if you see this, have a go. its really good!!
Front Room lots of straight edges
Garden in ultrawide. Looks more 'normal' to me
