My name changes to default and old gear still shows up on my profile
695 10 2024-7-11
tgchan
Poland
Good day,
I have a problem with my nickname reverting to default one: fans55aab121
Every other time I log in it goes back to this... instead staying how I have changed it: tgchan
Also, my old gear: osmo pocket 1 still shows up on my profile despite contacting moderators about it...
My new osmo pocket 3 does not show on the profile...
Can someone fix it, please?
2024-7-11
DJI Thor
Flight distance : 13602 ft
Hi there, thank you for reaching out. You name is showing 'tgchan' at this moment. Would you please provide us a screenshot about the name issue? We will help you to further check with our relevant team.
For the icon issue, would you please PM me the serial number to confirm? Thanks.
2024-7-11
tgchan
Poland
Hello there/
I have changed it again when I logged in. I will log out and see if it reverts/
2024-7-11
tgchan
Poland
Yes, it changes when I log out ;(
2024-7-11
DJI Thor
fansbd8dd411 Posted at 7-11 23:02
Thank you for the sharing. We will further check with our team first and update you soon. Thanks.
2024-7-12
tgchan
Poland
Hello, thank you for fixing  my dji gear icon under my avatar.
My name still changes to a random one... fans5a55d64b What is going on?
I am not changing it so you can change it and hopefully it will stick this time...
Please change it to "tgchan"
2024-9-20
DJI Thor
fans5a55d64b Posted at 9-20 23:06
Hi there, thank you for reaching out. You could change the name by the following path, thanks.
Path: Personal Homepage - Settings - Set my new username
2024-9-20
tgchan
Poland
I know. I change it every few weeks/months
Why does it change to some random thing?
2024-9-21
DJI Thor
fans5a55d64b Posted at 9-21 02:10
Hi there, we will help you to further check with our relevant team and revert you back soon.
2024-9-21
tgchan
Poland
2024-12-08 and it still has not been fixed...
fans5a55d64b
" Hi there, after checking with our relevant team, since the nickname you changed is the same as your email prefix, your nickname has been reset to "fansxxxxx". We recommend that you change it to another nickname. "
It is okay. I want to use my nickname just as everywhere else...
2024-12-8
DJI Stephen
tgchan Posted at 12-8 03:59
fans5a55d64b
Hello tgchan,
Thank you for your feedback, and we completely understand your concerns.
Regarding the forum naming rules, if you set a user name, but the user name is the same as your forum-registered email's pre-fix, (for example, you set your user name as Jone_Doe while your email is Jon_Doe@website.com), your user name will also be changed to "fans + random number". Could you kindly check if your user name is the same as your email name?
For more detailed information, you can refer to this post: https://forum.dji.com/forum.php? ... 1515&pid=623190
Thank you once again for your understanding and support.
2024-12-9
