Random camera restarts after shut down.
562 14 2024-7-13
Fishycomics
  It is random DJI mic 2 is on, all the latest firmwares. I 100% shut down to end my day, and a minute later  I hear the start up tone. after a second shut down, its off
2024-7-13
johansenfoto
Flight distance : 1180089 ft
Norway
Is your apartment haunted?
2024-7-13
Fishycomics
Was out in the Real world, that is hte problem.
2024-7-13
johansenfoto
Norway
I see. Will think the camera was in kind of a stand by mode and got a wakeup- signal.
Maybe it's possible to wake up the camera with some kind of hack in the future then.
2024-7-13
DJI Natalia
Hi there, thank you for reaching out and we do apologize for any inconvenience. May I confirm if your DJI Mic 2 randomly turns off while using? Also, kindly take note that DJI Mic 2 has auto power-off function and with this function enabled, the transmitter, when not connected to any device and without independent recording activated, automatically shuts down after 15 minutes of no use. You may disable this function in " Receiver Settings" in Control Menu.
If the issue still persists, kindly share us a video demonstration showing the exact issue for us to check further with our engineering team.
Thank you for your continued support!
2024-7-14
Fishycomics
DJI Natalia Posted at 7-14 23:55
we are not talking about the OFF, or auto off ,
2024-7-15
Fishycomics
johansenfoto Posted at 7-13 16:03
Maybe DJI is Spying on us
2024-7-15
johansenfoto
Norway
Fishycomics Posted at 7-15 02:32
Haha only on you then
2024-7-15
Fishycomics
johansenfoto Posted at 7-15 06:18
Lol if it was so
2024-7-15
BaynhamPhoto
Flight distance : 491814 ft
Think you confused the bot by adding mic 2 into that post Fish maybe qualify the issue is the Action 4 coming back on, that is what you meant?
2024-7-15
Fishycomics
you know I'll get it on film. you bet  have to keep them on their  toes
2024-7-15
DJI Natalia
Fishycomics Posted at 7-15 02:31
Thank you for the reply. We are sorry for the misunderstanding. Regarding your issue, may I check if your DJI Mic 2 receiver is connected to any camera via a 3.5mm TRS cable ? Looking forward to your reply. Thanks.
2024-7-15
Anonymous
2024-7-15
Fishycomics
osmonauta Posted at 7-15 20:37
https://forum.dji.com/thread-304739-1-1.html
Big- thank you. no resolution to it as three staff teams are on it. will be to placing a loose leaf  strip or two , possible the foam   aged of the battery door to cause the  battery to move . hardware/software no one knows
2024-7-16
FfoSuy
Singapore
Don't waste time with this. I would get a replacement set if it's still possible. Most likely a faulty contact with the on/off or record button. Good luck!
2024-7-19
