5.8GHz disabled on Osmo Pocket 3
1710 12 2024-7-19
chris974
Réunion
Hello,
In the user manual it is said "When Osmo Pocket 3 is linked with DJI Mic 2 Transmitter and working in the 2.4GHz Wi-Fi frequency band, Dji Mimo cannot connect to Osmo Pocket 3. Either change the Wi-Fi frequency band of Osmo Pocket 3 to 5.8GHz or disconnect DJI Mic 2 Transmitter before connecting to the DJI Mimo app."
And as said, when I connect the Mimo app it works, but the DJI Mic 2 is disconnected. Then in the camera parameters I try to set the wifi frequency to 5.8GHz, but it is disabled and greyed, only the 2.4GHz is available.
Any idea please ?
2024-7-19
DeNachtwacht
Flight distance : 241831 ft
It looks like your phone only supports 2,4 Ghz, and the Pocket and phone are connected via 2,4 Ghz? Then, it's not possible to also maintain a 5,8 Ghz connection
2024-7-20
chris974
Réunion
DeNachtwacht Posted at 7-20 05:21
hello, unless I'm mistaken, my iphone se 2nd can connect at 5.8GHz; moreover in the camera menu this frequency is grayed out and inaccessible, even when it is not connected to the mimo app
2024-7-21
DeNachtwacht
Looking at your screen, you're in a French country. It could be that 5,8Ghz wifi is forbidden in the country where you are? Or maybe you bought the Pocket 3 in such a country (for example Japan).
2024-7-24
chris974
Réunion
DeNachtwacht Posted at 7-24 12:55
Thank you for response but we can use both frequencies
2024-7-24
Scarlett G
chris974 Posted at 7-24 20:25
Hi there
Have you tried other type of phone device and repeated all the operations above?
Maybe it can help you to find out if the phone device problems or others.
2024-7-24
chris974
Réunion
Scarlett G Posted at 7-24 22:56
Hi there
thank you for the advice ; I have tested with an Android phone ; same result ; anyway the 5.8 is disabled even when no memo app is connected to the camera
2024-7-25
Thevion
Flight distance : 549925 ft
Poland
Try resetting the camera to its factory settings. I had a problem with 10-bit image in Action 4 and after a factory reset the problem disappeared
2024-7-26
chris974
Réunion
Thevion Posted at 7-26 03:04
Hello, thanks for the advice but I have to send the camera back due to a problem with the mic 2 (in the combo) ; I hope the new one not faulty ;-)
2024-7-26
chris974
Réunion
No change with factory settings ; as I have another problem with the Mic 2 (this is a combo) I'll send it back for replacement.
2024-7-29
Motorider98
Russia
Я нахожусь в России, и для нас 5.8 в конфигураторе выключен. Говорят в других странах работает.
2024-10-13
chris974
Réunion
Motorider98 Posted at 10-13 14:32
поэтому, вероятно, это тот же случай, что и у меня, но DJI, к сожалению, не общается по этому вопросу
2024-10-13
Motorider98
Russia
chris974 Posted at 10-13 19:47
Был получен ответ. Для России и Украины этот тип стандарта отключен.
Dear Customer,
Thank you for contacting DJI Technical Support!
We are sorry to inform you that DJI has temporarily suspended all business activities in Russia and Ukraine from 00:00 on April 27, 2022 (Beijing time). Here is the information for your reference:  https://www.dji.com/newsroom/news/dji-statement-on-sales-compliance-efforts Thanks for your understanding.
Thanks for choosing DJI products
2024-11-5
