L2 Accuracy Issues
620 5 2024-7-21
djiuser_qSkwMnFPV8Lz
Hi All,
I am looking for tips on how to improve accuracy.
We have now purchased L2 and after several flights we continue to observe vertical accuracy error greater than 1m accross all tests. (See image)
Data is captured with RTK on, Ntrip corrections with base less than 1km away, GCPs are surveyed by conventional method.
Any thoughts what might be the issue here?
Our nextstep would be Re-calibration process but not sure if it should be neccesary for a brand new unit.
Also, has anyone tried L2 on double mount with no 2nd Payload? Manual recommends Single mount for single payload, but has anybody tried on dualmount with Only L2?
2024-7-21
LV_Forestry
Flight distance : 4726654 ft
Latvia
How precisely were the coordinates of the base measured?
"GCPs are surveyed by conventional method" / What does it mean ?
The arm lever is calculated between the GNSS antenna and the single payload support. Using dual will cause an offset.
2024-7-22
Scarlett G
Hi \
Have you contacted the DJI support and ask for assistance?
Maybe it's the fastest way to resolve your problem.
2024-7-22
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
Which settings are you using on your L2 during the flight? We use L1 and L2, L2 accuracy is quite good. Never had so much difference. Dual mount is not recommended for mapping activities
2024-7-22
PDH
Flight distance : 8252644 ft
Potential positioning error between MGA94 and MGA2020 datums?
2024-7-22
Ok, Thank you all for your input.
Here is some info.
1. MGA94 vs MGA2020 - We have considered this scenario and checked through the coordinate systems used. All steps of capture and processing were in GDA2020/56. After further investigation, it is not related to wrong datum as the differences between checkpoints are not uniform. each has shown different error.
2. We have now tested both, Single and dual mount with only L2. Both test show same results.
3. We tested in 2 different scenarios. - Ntrip Only and Emlidrs2+ as base station. GCPs we shot with Leica and Emlid GPS units.
4. We followed the recommended processing workflow for Terra, including adding Rinex data with .obs, adjusted base station location x,y,z and GCPs import, again all in GDA2020/56
Terra processing Settings in photos.
Any idea where that error might come from?
Do we need to re-calibrate?
2024-7-23
