DJI FPV Remote Controller 3 Release Notes (09/05/2024)
4483 24 2024-7-25
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2024.09.05
  • DJI FPV Remote Controller 3 Firmware:        v01.00.0300
What’s New
  • Added support to use with DJI Neo.
  • Fixed some known issues.
Notes
  • Restart the aircraft, remote control device, and goggles after the firmware update is complete.
  • Note that the firmware update may reset various flight parameters such as RTH Altitude and Maximum Flight Distance. Before updating, take note of your preferred settings and readjust them after the firmware update is complete.
  • Note that the firmware update may reset the customizable button settings. Before updating, take note of your preferred settings and readjust them after the firmware update is complete.
  • If the update fails, restart the aircraft, remote control device, goggles, and the DJI Fly app or DJI Assistant 2 (Consumer Drone Series), and try again.
Overview:
  • Date:2024.07.25
  • DJI FPV Remote Controller 3 Firmware:v01.00.0200
What's New?
  • Added support to use with DJI O3 Air Unit.
Notes:
Overview:
  • Date:2024.04.11
  • DJI FPV Remote Controller 3 Firmware:v01.00.0100
  • DJI Fly App iOS:v1.13.0
  • DJI Fly App Android:v1.13.0
What's New?
  • Optimized communication stability between the goggles and remote control device.
Notes:
2024-7-25
Jnaron
Flight distance : 107057 ft
look what i found in the new goggles 3 after the last update
2024-7-25
djiuser_pdGgqSGWl0nK
Jnaron Posted at 7-25 11:08
[view_image]
Very exciting
2024-7-25
djiuser_NbhMqOxxFsFQ
Argentina
How can you operate the control with the o3?
2024-7-25
DAFlys
Great news,    so when will Avata 1 and Mini 3 Pro get supported?
2024-7-26
DJI Gamora
djiuser_NbhMqOxxFsFQ Posted at 7-25 18:47
Hi there,
Thank You for reaching out. Firstly, you need to update the firmware to the latest version on all your DJI devices and restart them. Upon restarting you can connect your DJI FPV Remote Controller 2 or DJI FPV Remote Controller 3 as usual. You can refer for activation and linking here About DJI O3 Air Unit.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-7-26
DJI Gamora
DAFlys Posted at 7-26 01:06
Hi there,
DJI has not announced any news about the compatibility for DJI FPV Remote Controller 3 with DJI Avata or  DJI Mini 3 Pro. However, we will consider this as a suggestion. Your valuable feedback will be promptly forwarded to the relevant team for a thorough evaluation. We would like to assure you that we are committed to providing the best user experience. Thank you for your continued support.
2024-7-26
DAFlys
DJI Gamora Posted at 7-26 03:38
Hi there,
Sorry DJI Gamora I was refering to the goggles 3,  as thats the picture that was posted at the top of the thread.
2024-7-26
Argentina
DJI Gamora Posted at 7-26 03:24
Hi there,
Thanks, if you synchronize the glasses, but the controller has not been able to, it does not synchronize in any way. everything updated, I have the fpv controller 3
2024-7-26
spoonflames
Thank you DJI!
2024-7-26
DJI Gamora
DAFlys Posted at 7-26 04:13
No worries, I have forwarded your feedback to the related department for evaluation. As of now DJI has not announced any news about the compatibility of the new Goggles 3 with the DJI Avata or DJI Mini 3 Pro.
Stay tuned for the latest release updates on the official DJI website or DJI Forum. Thank you.
2024-7-26
DJI Gamora
djiuser_NbhMqOxxFsFQ Posted at 7-26 05:20
Hi there,
Thank you for reaching out. May I know are you using your DJI O3 Air Unit mounted with DJI Avata 2? Please send us a video recording, footage or error message of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-7-26
AlexCarboni
Flight distance : 5302175 ft
Today I updated my djio3 and switched to the new dji goggle3 visors... terrible result,
I lost the signal 2 times flying at the usual field that I know very well and where I usually never lose the signal with all ather my fpv drone.
after updating the firmware on the Unit O3 and on the DJI Goggles 3 with the radio control too ,
I made some flights in the usual field where I usually work to test if everything was working well...
so , when I pass near an area where I know there is interference, the drone disconnects, going from 30Mbts to zero, immediately. (witout any warning)
I tried three times and it was always the same result “disconnected”.
then the same test done by connecting the drone to the old goggles V2  following the same lines
and despite  the signal lowering a bit ,  from 30Mbts it goes to 20Mbts  the drone does not disconnect.
All test done in automatic channel and video recording 4K 120fps setup .
really disappont with DJI
link of video on FaceBook account
2024-7-31
DJI Gamora
AlexCarboni Posted at 7-31 07:09
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing.
Kindly check as per the troubleshoot below;
(1) Check whether the firmware version of each part is the latest.
(2) Check whether the top of Air Unit antenna is correctly installed with no obstruction.
(3) Check the distance and altitude when the image transmission is disconnected or the remote controller signal is lost during the actual flight.
If issue still persist, kindly DM us the logs of Air Unit and goggles via google drive or dropbox.
2024-8-16
Antdrones
Flight distance : 1253035 ft
Yikes, would you suggest me seperately getting goggles 2 and a seperate fpv controller (was thinking the boxer or tx16s)
2024-9-16
AlexCarboni
Antdrones Posted at 9-16 09:52
at the moment I would advise you not to update the dji unit O3 and wait for dji to solve this bug.
if you already have a dji unit O3 on your drone,
continue to use the old goggles 2 or dji integra ...
because the compatibility with goggles3 at the moment does not work well and can cause sudden signal loss.
2024-9-17
Antdrones
AlexCarboni Posted at 9-17 00:27
Ok well is it worth it to buy a pair of goggles 2 to connect to an o3 air unit? I was planning to build my own drone.
2024-9-17
AlexCarboni
Antdrones Posted at 9-17 05:18
with the dji unit O3 I am STILL using my old goggles.
So at the moment yes, they are the most compatible and efficient visors for our self-built fpv drones.
my regret is not being able to use (and therefore bring with me) only one model of goggles for all my drones ...
( DJI please ... fix this problem as soon as possible, because the compatibility declared by the new firmware does not work )
2024-9-17
Antdrones
AlexCarboni Posted at 9-17 06:20
Ok i guess i will wait a bit, hopefully dji fixes this soon.
2024-9-17
AlexCarboni
Antdrones Posted at 9-17 08:54
well , it depends on what you want to do and how much of a hurry you are ...
I hope DJI fix  it soon ... and that we can use the same goggles3 and RC3 for all our fpv drones, both dji and self-built ...
2024-9-17
Antdrones
AlexCarboni Posted at 9-17 14:09
Im in no rush, just want to get in to traditional fpv since the avata 2 has many limitations and i want to work towards becoming an fpv pilot.
2024-9-17
AlexCarboni
Antdrones Posted at 9-17 14:30
in this case ... all right ... if you can , wait until dji unit O4
2024-9-17
Antdrones
AlexCarboni Posted at 9-17 14:44
No the goggles are compatible with o3 unit already but people say its horrible and disconnects after any obstacle.
2024-9-17
AlexCarboni
Antdrones Posted at 9-17 15:55
Exactly what I’m saying…
Dji goggles 3 with last update and dji unit O3 with last fw , as per declarations are now compatible…
But many users , including myself still have issues with suddenly losing of signal.
So … In my opinion
At the moment it is much more better to use goggles2 or V2 with dji unitO3 which usually don’t have any issues and works good …
Maybe in the future dji will work in some update to fix this problem… but this is on the dji hands
2024-9-18
Antdrones
AlexCarboni Posted at 9-18 05:59
Oh ok got it, thanks for the help
2024-9-18
