How to make a 2d map with thermal images? Flight Hub?
919 5 2024-7-27
WolfWeb
Flight distance : 136371 ft
Relatively new user here, I can make a 2d map with normal wide angle images in Flight Hub 2
But when I choose a folder with thermal images, I get the error of not enough images and an info button which shows: "Only wide-angle photos supported for mapping"
So how can I make a 2d map using thermal images? What software can I use?
I can make it with mapsmadeeasy.com but was hoping for a different solution
2024-7-27
Johnnokomis
Flight distance : 14031719 ft
I'm not sure. If you can share an example dataset with me through Google Drive or other file sharing service, I'll find you an answer.
2024-7-27
NewEnglandDroneServices
I have the same issue!  I saw one video where they just glossed over making the map.. they provided no details on how it was done.
2024-11-7
DarkZero
Flight distance : 923127 ft
I have built 2D thermal maps in ESRI Drone 2 Map, Bentley iTwin Capture Modeler, Pix4D and many others with great results, you need plenty of overlap, more than you typically would with RGB capture. This tutorial may help you
2024-11-10
djiuser_NvT4sGaall9O
Did anyone figure this out...having the same issue. Trying to map thermal in 2D and getting the same "less than 5 wide angle photos"...any help would be appreciated.
1-6 22:25
I got online with Tech support....currently DJI FlightHub2 only supports thermal reconstruct pirctures taken by thermal camera in real-time construction. Real-time reconstruction needs to be triggered in DJI Pilot. When the aircraft is in Mapping mode and DJI FlightHub 2 is connected, there is a cloud reconstruction option in Waypoint Route Checklist. Enable the option and photos captured will be automatically uploaded to DJI FlightHub 2 for reconstruction. The reconstruction processing is similar to the real-time mapping of DJI Terra. Photos will be uploaded for real-time reconstruction. The reconstruction result is synchronized to the map interface of the app and DJI FlightHub 2 in real time, and the images will be added in real time. After data collection is completed, data optimization will be performed to generate final result. It takes a certain amount of time to generate the final result, and the result image is slightly different from the real-time mapping image.
1-6 22:51
